Hitachi 60VS810 60" Rear Projection HDTV-Ready Television Logo
tyler lavern Posted on Dec 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen is green? - Hitachi 60VS810 60" Rear Projection HDTV-Ready Television
Anonymous
Level 3:
Top Expert:
  • Hitachi Master 14,553 Answers
  • Posted on Dec 15, 2012
Anonymous
Hitachi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718498
Points
48227
Its a Dlp set? uses a lamp, if so you have a bad optical light engine, usually a oval area the wrong color in the middle of the screen.
Screen turns green and tv powers off.
visit your local service center. you cant do anything more up to this point
2helpful
I have no picture, only green screen and audio when I turn on
i have no picture the sceen is green but i have sound can u help thanks.
Green screen projection
This is the exact same issue as I described for an Epson user. So I'll repeat it here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the green color has gone out. The image is made up of red, green and blue images layered upon the screen. If the green panel has gone out then there is nothing filtering out the green light in the image. This causes a nice green hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
3helpful
Hitachi rear projection tv. screen looks green
Green CRT bad = take off lower front cover, remove access panel
locate screen / focus block.....turn green screen control slightly
CCW............................re-assemble...........T.
2helpful
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
1helpful
Green Screen
check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
RCD 52W20 with no green...
Re-check hook up on focus/screen adjust assembly.Adjust RGB screen controls.All green/ no control can be bad green CRT==check w/CRT checker.CRT OK/==diagnosis required.Green video drive circuit??
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
