SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
[email protected]
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
SOURCE: will not correctly switch between different HDMI
I have the exact same problem/symptom. I suspect this is a very common problem only folks just now discovering it as we buy new hdmi devices. I called technical support and got the "sorry, out of warranty" talk. Mr Badge #74754 claimed that this was not a known problem. Would love to hear of others having this problem.
SOURCE: my e420vo vizio wont turn
Did you ever find out what was wrong? This happened to me just now!
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
