If you're using component cabling (red, green, blue cables) a black and white picture will occur when only the green cable is plugged in.
If you're using HDMI cabling, try a different HDMI port and see if your color comes back.
If not, unplug the set from power for a few minutes, plug it back in and see if problem persists.
If you still have the same problem, check the DVD player on another TV. If it shows color on a different TV, then your TV will need a replacement digital board which we can check availability on once we have a specific model number. If it's black and white on a different TV, then you have a problematic DVD player.
SOURCE: my dvd player keeps coming up in black and white
sounds like the video processors on the input are bad
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
SOURCE: Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
SOURCE: black and white grainy output to new samsung lcd
Your DVD player is using a PAL or NTSC variant which is not supported by your display. Somewhere hidden in the depths of the options in the DVD player should be an option to change the composite output type.
