How do i set my own ringtone
What kind of phone? Most newer phones have apps you can download for free to make your own ringtone but especially for iphones it is not easy. If you are somewhat tech savvy search your phone model in google and "custom ringtones"
If not so tech savvy its easiest to shell out the money for a already made ringtone of the music you want. Only purchase ringtones from official stores on your phone
Ex; Iphone: Itunes
Android: android market or google play.
I suggest not using your computer to buy ringtones or searching for ringtones on your computer browser in general. Theres lots of scams out there.
You can use iTunes to make any song as iPhone ringtone.
Step 1: Download iTunes on your computer. Make sure you have downloaded and installed the latest iTunes on your computer.
Step 2: Import the song to iTunes. Then, right-click the song and then choose the tab of "Song Info" from the drop-down menu. Hit on the "Options" tab to set the start and stop time to ensure that it is within 30 seconds. Hit "OK" button to continue.
Step 3: Select the loaded sound file in iTunes and click File >> Convert >> Create AAC Version. Wait for some seconds, the MP3 would be converted to AAC format.
Step 4: Go to the saving route and locate the AAC ringtone file. Next, right click on the AAC file and you can rename and change the file extension to .m4r.
Step 5: Add the ringtone to your iPhone. You can use iTunes to sync the ringtone to your iPhone, or use third party app like Leawo iTransfer to transfer ringtone from computer to iPhone directly.
Read on this tutorial to learn more: https://all-things-about-apple.blogspot.com/2021/05/how-to-change-iphone-ringtone.html
Great! Also, you can check here
Go to My Files, then Device Storage, and locate the folder where your downloaded music is located. Highlight the music you want...https://freshpikk.com/electronics/comput...
First and foremost, you have to download your favorite songs from PC (navigate to part 1 in this guide if you need a detailed operation: https://bit.ly/3a3kvom), and then just transfer these songs to your phone via USB cable.
If you mean an iPhone that you can't set any music as ringtone, you can follow below steps to custom the ringtone correctly.
If you want to get how to change ringtones on iPhone 8, you can simply accomplish it on your iPhone 8. What you need to do is open your ringtone settings to set ringtones on iPhone 8. How to change ringtones on iOS 10? Let's see how.
1. To set ringtones on iPhone 8, you need to open the settings app.
2. Tap on "Sounds" and head to "SOUNDS AND VIBRATION PATTERNS", then press "Ringtones".
3. You will see a list of ringtones under "RINGTONES". Simply tap on the ringtone you want to change and you will see a tick before the ringtone name, which means you complete how to change ringtones on iOS 10.
If this method can't fix your issue, check this guide for more methods. How to Change Custom Ringtone on iPhone 8
