Question about Pioneer PRO-710HD 64" Rear Projection Television
Can I use a universal remote to adjust my settings for the elite Pro 710 HD?
Posted by app_3rp8020 on
SD Tech
    Top Expert:
  • Pioneer Master
  • 14,553 Answers
I doubt it, we have in our shop about five of their remotes and each only works on one or two models--bite the bullet to get another or if you have the original but it does not work, most shops can fix that for a reasonable price.
Posted on Dec 15, 2012
5 Related Answers
Anonymous
SOURCE: cannot program my universal remote
buy the exact remote from parts store.com
Posted on Apr 12, 2008
MrBob84
Robert Jones
  • 90 Answers
SOURCE: Pioneer Elite Pro 710 HD
If your Elite 510/610/710 - and the earlier 520/620/720s - works fine when you turn it on but starts to go hinky on its reliability once it has warmed up, you still have a shot at getting that sit remedied for a very nominal fee - or nothing, if you know what you're doing and are an electronics professional. Those models were improperly soldered at the factory on their PS boards. Those PS boards took years to go bad, but now that the constant barrage of expansion and contraction of the too-thin solder joints has started its inexorable journey towards taking down your set, the clock is ticking. You don't have much time.
One thing is very important, and I can't stress it enough: STOP USING YOUR SET NOW. Things could get much worse if you do. That means NOW, even if you are watching it right now. A deadly spike caused by the bad solder joints currently on that power supply board could be getting ready to be produced by a connection that is getting ready to separate as we speak, and that spike could take out one or more of the boards downline. One guy who called me had kept using his set for months with these intermittents happening, and eventually both the converence and the deflection boards went out, both in an instant. The set would not turn on again, and built-in indicators on the circuitry showed 3 boards now needed attention. With 3 boards to now have to deal with, he decided not to get his set repaired at all, due to the now tripled expense. His set was now totalled. It tears my heart out when one of these fine machines goes down for the count because of misuse - continued use when it's obviously hurt - and is then DNR'd by its owner. That all could have been avoided by taking action promptly rather than continuing to tempt fate, on his part.
Send me an email requesting it, and I'll send you back an emailout on how to remove it, what it costs, how to wrap it and send it, where to send it, etc. I can't divulge certain aspects of all this on the net here, must keep some of it close to the vest. Will be glad to tell you personally, by email or on the phone.
I will tell you this much - I charge $275 for the resoldering op, you pay the shipping both ways. That's less than it costs to get a replacement board from Pio and have a local Pio warranty station install it.
Keeping the same board in your set rather than replacing it is the way to go, IMHO. That way the voltages it was set up with originally, stay the same. If you get a replacement board, those voltages can be very different, affecting the precision of settings downline. Voltage regulation only has to fall within certain parameters, so different PS boards will produce different sets of voltages. The PS board and your set are now a matched pair. The best way to retain your precision in downline sets of settings, is to keep your original board in the set, the one your set was originally set up at the factory with.
To find the PS board, follow the power cord from the wall. It will lead you right to it. Use the big bubble-wrap to send it rather than the small stuff, and box it in an oversized box for the journey.
Mr Bob
www.imageperfection.com
[email protected]
Posted on Sep 01, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: the convergence chip is going in my pioneee elite
Yes there are two ICs in your model they are around 20.00 each for quality ICs. Cheaper ICs are available but I wouldnt recommend them as theyre most likely the inferior chineese made ICs and they fail quickly.
Posted on Nov 27, 2009
Jason Johnson
  • 1619 Answers
SOURCE: Panasonic Pro 710 HD Shuts off for no reason
Most likely bulb is dying and cooling fans are clogged with dust. The bulb iis more like a street light than a home bulb.
Posted on May 15, 2010
Azrael SRL
  • 11800 Answers
SOURCE: I get bright flashes on
Bright flashes in a CRT tv means that you get high tension discharges in the video final board which in turn trigger a power surge that cause the tv to shut down.
You didn't said which colour is the flash so i 'm supposing that is white. This mean that the discharge is affecting all 3 tubes at the same time, which means that you must verify the high tension leads, the flyback transformer and all the groundings on the tubes. Also verify the static dischargers on the video board.
Posted on Nov 20, 2010
Hello how do i set the convergence manualy on a pioneer elite pro-710hd projection tv i dont have the remote and dont know how to bring the menue up on the tv
You MUST have the remote to perform service operations on the Elites. Look on ebay or do a google search for Pioneer 710 remote.
There is no way to manually do convergence without a remote, and no way to call up the convergence menu.
Feb 05, 2014 | Pioneer PRO-710HD 64" Rear Projection...
My remote for my Pioneer Elite BDP-95FD died. Is it possible to get a universal one as a replacement?
You most likely can use a universal remote to control this device, you will just have to search for Pioneer bluray player radio codes that you can configure on the universal remote.
Oct 16, 2013 | Pioneer Elite BDP-95FD HD-SDI upgrade
The convergence chip is going in my pioneee elite
Nov 27, 2009 | Pioneer PRO-710HD 64" Rear Projection...
Code dvd Sharp for RM-101 universal remote
Instructions on how to set up / programme a universal remote:
1) See the code form and find the 3-digit figures for your device.
2) Press "SET" button and hold continuosly, then press the device select button (e.g. TV1, TV2, VCR, SAT, etc. If you are setting up for your TV, choose TV1) you want to control.
3) When the indicator light is on, release the two buttons simultaneusly.
4) Enter the 3-digit figure you have found.
5) When the indicator light goes out, programming is finished.
6) Check whether operation of other buttons is at normal state. If so, your setting is successfully accomplished.
Below is a list of the 3-digit code for a few more popular TV brands that are sold in Singapore. If you have a different device (e.g. VCR/LD/VCD/DVD/etc), and/or of a different brand, please do post your queries here, everyone can contribute and help one another ^0^ Here goes~!
Aiwa: 261
Daewoo: 168, 209
Elite: 108
Goldstar: 003, 004, 043, 080, 153, 172, 252, 700, 701
Hitach: 004, 040, 041, 042, 044, 047, 055, 061, 062, 063, 064, 065, 066, 067, 068, 174, 221, 222, 710
JVC: 077, 119, 178, 179
Matsui: 004, 006, 028, 041, 088, 182
Mitsubishi: 044, 052, 092, 119, 154, 155, 181, 182, 245, 707
NEC: 184
Panasonic: 001, 003, 019, 037, 040, 106, 110, 111, 112, 114, 190, 241
Philips: 003, 026, 027, 046, 073, 113, 115, 155, 191, 192, 193, 194, 223, 266, 230, 242
Pioneer: 000, 027, 067, 243
Samsung: 026, 033, 04, 159, 160, 170, 175, 212, 215, 702, 703, 716
Sanyo: 013, 031, 044, 074, 119, 120, 121, 122, 123, 162, 167, 170, 182, 195, 205
Schneider: 004, 011, 015, 019, 025, 036, 038, 255, 258, 262
Sharp: 044, 054, 119, 124, 196, 198, 225, 227
Siemans: 010, 231, 232, 233, 234, 236
Sony: 028, 119, 126, 127, 128, 129, 130, 182, 199, 228, 260, 705
Tai Wah: 218, 219
Thomson: 065, 067, 075, 078, 098, 100, 103, 185, 186, 222
Toshiba: 022, 044, 094, 119, 138, 139, 141, 142
Aug 05, 2009 | Universal Remote Control Remote Control
I can't get rid of closed captioning!
Closed captioning can come trough 4 sources 3 of them access a digital file and display it to the screen. ALL must be set to off on each device:
Embeded in actual program video source--unlikely your problem.
TV decoder cotrolled by TV menu under "language"
Cable box--ditto for menu selection
DVD player or VHS tuner--Ditto for menu
Sep 17, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Popping and Screen Goes Dark
I have the same power pop off on out elite 710 hd. Can you tell me what to check firts, where the board is I need to check, and what it costs to fix? Is there anyone in SC, do I need to send out? Any help would be greatly appreciated!
dorinda
May 30, 2008 | Pioneer PRO-710HD 64" Rear Projection...
HD CONVERTER FOR COMPONENT
Just Google hdmi to component....You'll find plenty of choices.
Jan 10, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Cannot program my universal remote
Oct 25, 2007 | Pioneer PRO-200 60" Rear Projection...
Pioneer PRO-710HD 64" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Demonic-2011
Demonic-2011
Raj Patel
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
