Doesn't matter if i turn my oven on bake on conv bake, the oven say its on and heating up, but the temperature never raise and the element don't get hot. i was thinking its a bad temperature probe problem or a element problem. so how do i tell the difference and so how i solve my problem?
Hello Jacob J - Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective and oven does not bake or broil contact a professional to move forward accurately. Range could possibly be experiencing an issue with a wiring failure, EOC, sensor probe and/or faulty elements which would need further diagnosing.
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
SOURCE: Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
