Question about Bush DVD142RC 14 in. TV/DVD Combo
My daughters 24 inch bush led/ dvd combi has started to play dvds in black and white. the normal tv picture is fine. does any clever person out there know how to fix this problem? would be very grateful
Posted by steven jones on
    Top Expert:
  • Bush Master
  • 76,587 Answers
Laser pickup unit fault. It should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on May 12, 2015
5 Related Answers
Anonymous
SOURCE: BUSH TV/DVD combi
connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
Anonymous
SOURCE: Hi can anyone please let me know the code for 4 in
I'm looking too, but no luck yet. I'll let you know if I succeed.
Posted on Feb 10, 2011
gopakumarg43
  • 76587 Answers
SOURCE: Hi there, I purchased a
Hello
There are two possibilities for this fault. The first one is the spinning problem of disc inside it. If loaded disc does not spins, the mechanism will eject it. The reason for this is damaged sled motor. Sled motor is one which spins the disc inside at high speed. It can be replaced. The second reason is of Laser Pickup Unit itsef. If it does not emit laser beam, the main system circuit will recogonise as there is no disc in the tray, and play function is energised, and will eject the tray out. Check for the first one. This is most comon fault with DVD players. OK.
Posted on May 30, 2011
Testimonial: "I will give it a try, thanks...."
Anonymous
  • 34 Answers
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Posted on Nov 05, 2007
Anonymous
  • 416 Answers
SOURCE: tv/dvd combi - dvd read problems
No it is not worthy, you will spend around $100, but brand new combo 13'' cost $80 and DVD starts from $22. You can use an external one.
Posted on Dec 02, 2008
Bush tv combi led24265dvdcntdfvpxy dvd will not play.
Have you tried DVD lens cleaner, More than one shop bought DVD disc and 1. Menu 2. Scroll down to installation press ok 3. Scroll down to first time installation 4. Scroll left for yes press ok then once reset follow on screen instructions to set this back up.
If this failed follow link below:
https://www.argos-support.co.uk/6693954-bush-24-inch-hd-ready-smart-tv-with-dvd-player-black
Jul 14, 2018 | Bush Televison & Video
Bush tv / dvd combi modle .. led24127fhddvdp as started to play in black and white how cam I change it back
Make sure you have the correct country chosen in the initial setup. If the TV is setup for an NTSC country and you're in a PAL country or vice versa, the picture will be in Black and white.
Feb 08, 2017 | Bush Televison & Video
Most Big box stores have a DVD cleaner disk, located in the electronics section, which is fairly inexpensive. I would try that first.
May 20, 2014 | Bush DVD142RC 14 in. TV/DVD Combo
My combi tv only plays dvds in black and white
mines just gone the same way after less than 2 years of having it and Finlux do offer to repair but it does have a year guaranty
dont think i'll be buying another.
Finlux (JTM)- 0800 737 247 -Collections/spares/chargeable repairs/returns dept.- Select option 2
only thing to try i'm affraid
Apr 12, 2014 | Finlux 19H6030 19" LED TV 1280x720, 50 Hz,...
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Alba led16911dvd
my dvd combi works fine but only plays the dvds in black and white and the dvd part of the remote doesnt work
Jan 19, 2012 | Albatron Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
BUSH TV/DVD combi
Oct 07, 2006 | Bush DVD142RC 14 in. TV/DVD Combo
Bush DVD142RC 14 in. TV/DVD Combo Logo
Top Bush Televison & Video Experts
Raj Patel
Tom Chichester
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
