I bought a used phone yesterday and everything worked until i plugged it in to charge the battery. It turns on and the side buttons work but i cannot use the touch screen. I am receiving texts and calls but cannot access them without being able to use the screen. Could it be the sim card? I used my old card from the phone i replaced. Tech said it would be fine to use. I have reset the battery. Changed the battery. Taken everything out and let it sit but nothing is working. Pls help!
SOURCE: pantech matrix phone doesnt read sim card.
How can I load #'s from my SIM's card to my new Pantech Matrix?
SOURCE: unlock prepaid pantech c120 to use SIM card from contract phone
That sounds like a feature to me. I suggest you use that to your advantage and put in some prank calls.
SOURCE: Pantech c740, will not stay on, w/new battery
Sounds like the phone is malfunctioning, I would probably replace it.
SOURCE: My pantech matrix cell phone says insert sim card
This problem arises sometimes because the mobile is unable to read the SIM. May be you should fold a small piece of paper in the same size of the SIM and keep it on top of the SIM and then insert the Battery. I think this will solve your problem.
SOURCE: i can receive text but
Hi the problem you are having is with your message center number this is a common problem and usually happens after you have changed your sim card to another network all you need to do to solve this problem is call your service provider and tell them the make and model of phone you have then ask them for the correct message center number.
they wont charge for this and they will tell you how to set it up, you will also need to ask them to send you the latest wap and mms settings so you can use the net and send and receive picture messages. they wont charge for this either and they will send you these settings via txt message and this will then update your phone to the latest settings.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
