Alpine MRV-F345 Car Audio Amplifier Logo
Eddie Posted on Dec 14, 2012
I am looking for a part number for the MPC722 resistor in the F345, or wiring diagram, manual etc. to find it.
Resistor is at loactions 170 or 270 on the board. It is marked with "MPC722 / 0.1K + 0.1ohmK / # 62A."
I have a Stoves 720 EF which failed when the cooling fan and resistor blew. New resistor and fan fitted but cooling fan only turns very slowly and resistor heats up immediately. Where do I look next?
Check how you wired the resistor. The resistor controls the speed of the fan. If its wired wrong, you will get the wrong speeds and the resistor will get very hot. Its normal for them to get warm but not so hot they start to burn. There should be a wiring diagram somewhere on the stove so you can check and confirm if one or more of the wires have been put on back to front.
1helpful
All my fuses are good and have replaced the blower motor resistor but my ac/heater will not blow air. no lights come on, on the control when i crank the car. 2001 buick regal ls
If you don't know how to look at a wiring diagram an test the electrical circuit for the blower motor ,do yourself a favor an take it to a qualified repair shop.
Blower Motor Problems Auto Repair Help
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on HVAC ,then under subsystem HVAC controls will pop up . Click the search button then the second blue link . Provided your vehicle has manual HVAC an not automatic . Automatic system doesn't have resistor , use blower motor control processor .
Blower Motor Resistor Function and Diagnostics
3helpful
4answers
Heater wiring diagram for 89 Corvette
The blower control module may be faulty?
Only the fan climate control is not working. The display climate control is working but only the fan.
That is the heater / AC blower motor ! There are electrical circuits and relays and blower motor resistor , blower motor etc... Electrical testing is the way to diagnose blower motor circuit . Looking at a wiring diagram to see what controls the blower motor on your particular vehicle would be the first step in diagnosing your problem . Do you know how to do automotive electrical testing , how to read or follow a wiring diagram ? Videos on youtube show how to test blower motor and related parts and wiring . Blower Motor and Resistor Diagnostics by Wells
Why is my blower not working to my heater?
Fuse , relay , control head , blower motor is bad , resistor etc... You need a wiring diagram an a volt meter an test , that's how you find out what's wrong . www.bbbind.com fro free wiring diagrams . Heater Blower Motor Troubleshooting Test And Replace Blower Motor Resistor Chrysler Town Country Caravan
5helpful
2answers
BLOWER HEATER FAN SWITCH IS ONLY WORKING ON HIGH SPEED WITH LITTLE HEAT.
The blower motor fan is controlled by the blower motor resistor.Its the resistor which controls the fan on respective speed which you select.But if the resistor goes faulty,then it will not be able to set the required speed which you set for fan,so it works on high speed only. In this case you will have to replace the blower motor resistor. Check fog for the location of blower motor resistor location:--- see part number 8 in the diagram below. helpmech_11.gif
The blower motor resistor is located next to blower motor under the dash.Its fitted with 2 screws and a wiring connector.You have to remove the screws and wiring connector and take the resistor out and place the new resistor in same position and connect the connector as well as screws. ------------------- this should help.Thanks.Helpmech.
My 2004 jeep heater just stopped working one day. changed out blower and resistor, but didnt fix the prob. went onlilne found out how to do the code reading thing, some howmade heat come back on, BUT will...
Automatic or manual climate control ? Looking at a wiring diagram an checking power an grounds an current draw is the correct way to test electrical circuits ,not guessing an replacing parts .
Why ???? High resistance problem probably . Volage drop testing the circuit. Your's has blower motor resistor or blower motor controller . module ?
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
http://www.bbbind.com/free_tsb.html free wiring diagrams .
1helpful
2004 Dodge Stratues blower motor control and resistor wiring
Ive changed tons of resistors on this vehicle. If your vehicle blower works on high speed and not on the low ones these resistors go bad all the time. I dont have the information you are looking for but what i am saying is if you are having a problem with it and dont know if it is bad -chances are 95% it is. just get a new one
1helpful
On fan switch keeps going on our 2004 Santa Fe. We have been told to also change the resistor. Does anyone know where the location of this resistor is>
Yep. Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
1helpful
1995 GMC Serria K1500 W/AC heater blower motor resistor loaction
its under glove box on passenger side. inside the cab... look at the vent box near the firewall. it located on that box and part of it is in the vent. you'll see the wires going to it and its held on with 2 7/32 screws
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
