Brother FAX-2920 Plain Paper Laser Logo
Posted on Dec 14, 2012
Unable to print brother fax 2920 , machine error 00?
5 Related Answers
Matt Dasse
  • 47 Answers
  • Posted on May 12, 2008
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Anonymous
  • 320 Answers
  • Posted on Feb 03, 2009
SOURCE: Paper fan folds inside the fax machine.
THERE IS SOME THING BLOCKING THE PAPER PATH, MAY BE PAPER OR SOME THING FELL IN THE MACHINE GOOD LUCK BROTHER TECH
Anonymous
  • 328 Answers
  • Posted on Jun 11, 2009
SOURCE: drum error message
check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Anonymous
  • Posted on Jan 20, 2010
SOURCE: Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Anonymous
  • Posted on Apr 20, 2010
SOURCE: unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Brother 2920 display unable to print pleas help me
hi
check the cable connection
check if you have toner in
check the drivers
2answers
2helpful
Changed the toner but it still says "unable to print"
Put the old tone back in machine. Does the problem still exist? If not try another new toner.
If it does then you may have a mechnical failure which will require a service center.
2answers
WHAT IS ERROR #202 MEANS
hello! i just checked the dervice manual for the rror202 that you said that you are having did not find that code could you clarify thanks brother sr tech
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Norman Weimar
Norman Weimar
k24674
