SOURCE: toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
SOURCE: Please help
Its located behind the video input board. it runs parallel with it and has a plastic bracket over it. Upi wont be able to see it unless you remove the plastic bracket
