SOURCE: universal remote code
I just bought one of those remotes to use on a Magnavox VCR because the buttons on the original remote are difficult to read (grey numbers on grey buttons).
The TV codes for Panasonic are: 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070. Good luck.
I had no luck with any of the codes given, so I tried the "Programming with Code Search" method and it worked.
1. Turn ON the device manually.
2. Press and hold the "P" button until the red light stays on.
3. Press and release the desired mode button (TV, VCR, etc.) The red light blinks, then stays lit.
4. Press Channel Up button repeatedly (up to 300 times) until the channel changes. (If you accidentally overshoot, press Channel Down to backtrack.)
5. Press and release the Enter button to set the code. (Mine doesn't have an "Enter" button, only an "ENT" button the left of the "0" and that didn't work, but I found the "M" button in the middle worked.)
SOURCE: Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
SOURCE: code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
