SOURCE: Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
SOURCE: HAVE CANON IR C6800 WITH THE FOLLOWING ERROR CODE... E000001-00ff
It is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the
issue. Another thing to check is the upper fuser roller for flat spots
this can also cause fuser error codes
SOURCE: Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
