Have been trying to load this for a while so any help would be great
You should be able to get XP 32-bit SP3 added. However, Windows Update will not work with XP SP2. Thus you will need to manually download the update and then install it. This is the link to the update: http://www.microsoft.com/en-us/download/details.aspx?id=24 . Click on the Download button. This is the version usually used for computers that aren't on a network.
I hope this helps.
(the Acer 1640z came with XP SP2; most computer companies support all of the service packs for their originally installed OS.)
Testimonial: "Many thanks for your help. It worked a dream "
The Service Packs must be loaded with Windows updated. Prior to the Service Packs their are many update to install. Let Windows update in a progression. One depends on another. Open Windows Update, in Control Panel. If you have Win XP and isn't up-to-date, you have a long row-to-hoe. The second Tuesday of every month is "Patch Tuesday" from MS. I resently did a recovery on a XP machine, it took 36 hours, stright to get it up-to-date.
SOURCE: Acer Aspire 1640z Format Problem
Jay:
Unless the hidden partitian has been written over or it has been corrupt...
Hit Alt-F10 as soon as you see the Acer logo when booting. If the recovery partitian does not display...then you must purchase an operating system and do it the old fashion way.
Good luck to you my friend.
Seek PCRepair
SOURCE: Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
SOURCE: Acer Aspire 1640Z BIOS problem
Dear all,
I also posted this one under "Notebook Bios Problems" which might notbe the correct place. Anyway here it is for you to see and maybe youcan learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS shouldI use i.e. how do I know if I need the AT or UMA version - how toverify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started but later I was all smiles
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
OF MONEY
SOURCE: acer aspire 1640z bios update
That's a memory or RAM error. You need to re-seat the ram of your machine.
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
