I have a Sony tv that the Chanel display stays on the screen. I don't have the orig remote. Any thoughts on that. Thanks.
SOURCE: lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
SOURCE: BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
SOURCE: I Bought a used TV which did not include a remote.
Yes, TV Remote will do the job by pressing display/ info button on remote and on-screen display will disappear.
SOURCE: I have the 2000 Sony
Hello
To turn the PIP feature ON and OFF press the button marked PIP on the remote contro. Each press will get it vanished and reappear. OK.
SOURCE: tv won't change from chanel to chanel
Do a hard reset to this set and check first. To make it hard reset, unplug the set from AC mains wall socket, and re-plug it back after 10 minutes or so.If this do not help you, check and replace its main system memory IC.
