SOURCE: Wireless Switch on Dell M1210
it's located on the side towards you is on toward the back is off.
SOURCE: need manual for dell xps 8300
Hi barbeedawg...
Go to the following webpage and download your FREE user manual and set-up guide.
Please take time to rate me thumbs up
http://support.dell.com/support/edocs/systems/xps8300/en/index.htm
SOURCE: Can I overclock the Dell XPS 8300?
Your processor can be overclocked by increasing the multiplier either via BIOS settings, or by using Intel's Desktop Control Center. It's worth noting that overclocking will void your warranty, cause your CPU to generate more heat and may cause your CPU to become unstable.
Wireless/Bluetooth keyboards and mice can only be used with one device at a time it is like a bluetooth headset once it is paired with a phone it will 99.99% of the time only work with that phone and that phone only, Wireless keyboards and mice are setup on the same principal once they are paired up with 1 PC to use on another PC you have to remove the pairing. The worst case scenario is that the second PC's Wireless/Bluetooth has failed. I hope this helps.
SOURCE: midi not being recognizes on dell xps 8300 windows 7 system
uninstall the drivers, and then reinstall them
