Power light not on fan running hard drive light on and no screen
Check/reseat monitor cables. If the fan and HDD are running, perhaps the power led is out. Check the monitor cable connections. Is the monitor plug into AC? Turned on? Shut down Desktop , unplug, reseat Graphics Card, if applicable, reboot.
Posted on Dec 13, 2012
SOURCE: ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Posted on Jan 19, 2009
SOURCE: Aspire AM1201 does not boot up.
hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Posted on Feb 17, 2009
SOURCE: Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Posted on Apr 13, 2009
SOURCE: I have an Acer Aspire M1641 desktop machine
Your machine has a hardware problem. Open the case and blow all the dust from it. Reseat all components you can. If that does not help, remove memory and try using one memory stick at a time. Change the memory slot. If it still will not boot you either have a video card, motherboard, or power supply problem.
Posted on Jun 05, 2009
SOURCE: Acer M1640 Aspire Screen black,no video or
Dear Dennis Lee Hanchar,
Thank you for contacting Acer
America. I'll be happy to assist you with this issue.
From your
mail, I understand that your system has an issue regarding boot up.
I
have verified your serial number and found that your system is out of
warranty.
I apologize for the inconvenience that you have
experienced.
Please perform a power reset in order to resolve the
issue.
1)Unplug the power cable from the back of the unit.
2)Press
and hold the power button on the unit for 30 seconds.
3)Release the
power button and plug the power cord back into the back of the unit.
4)Press
the power button and see if the unit powers up.
To resolve the
issue, If you are interested, we can pull your computer for depot
repair. However the system is out of warranty , we are extremely sorry
to inform that Acer cannot give warranty advantages. That means you will
have to pay for the repair . The cost for repairs will be 199$ USD.
Please note that you have to pay one-way shipping charge for making a
depot repair.
If you are ready for Depot Repair please confirm
it in your reply mail.
For further clarifications please feel
free to visit our web site http://support.acer.com/
Have a great day!
Respectfully,
Acer
America
Online Technical Support
Posted on Aug 11, 2010
One Long and Two Short Beeps
video display circuitry issue
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
