Question about Pride Mobility Products Pride Mobility Celebrity X 3 Wheel Electric Scooter
Back wheels lock suddenly
While riding my scooter the back wheels lock and come to a sudden stop its fully charged with 2 new battries fitted reently rewired when wiring the speedometer was bypassed so can only do 1 speed
Posted by Tracey Kimberlin on
4 Related Answers
Anonymous
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
Neil Wood
  • 177 Answers
SOURCE: My Pride Celebrity 3 wheel scooter, keeps suddenly
Hi. Sounds like a loose connection, either on the battery terminals, or on the battery lead connectors.
When your machine suddenly stops, does the battery gauge also turn off?
Can also be caused by a worn or stuck motor brush.
If none of these ideas help, can you give us a better description of what goes wrong?
Good luck. Neil.
Posted on Jun 27, 2010
Testimonial: "Thanks very much for the quick reply, I will get someone to check it all out. "
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: Batteries are fully charged. Scooter goes at full
Based on your description you have a bad throttle potentiometer or speed potentiometer. Remove the covers of the front console and check the resistance throughout the range of both pots at the connector. It should be even throughout the range with no dead spots. The newer CTE throttle pot is more reliable than the older model Celebrity scooter with the 5K ohm potentiometer. I usually replace the throttle and speed pots as a pair since they are connected electrically in the console.
Load test the batteries while you are driving. Using your voltmeter that is still connected under the rear cover while you are driving, check to see if you get a voltage drop of more than 1 volt. Static testing of batteries only tells you that there is a full charge. It does not give you an indication of how the batteries perform under load.
If you have clean brushes, you can still have a large amount of conductive brush dust in the motor and armature. Blow out the dust with compressed air. Check the motor and brake with you meter. The motor coil resistance should be less than 1.5 ohms and the brake should read between 40 to 60 ohms. Hope this helps.
Posted on Jan 05, 2011
lennieg2000
  • 692 Answers
SOURCE: I own a Pride Go
Problem seems to be in the brake wiring or micro switch on the brake itself that is causing your problem check the brake and wiring to make sure you have good connections and check if you can see that the micro switch is working correctly. try leaving the switch on and moving the freewheel lever to see if it will reset without turning the switch off if it doesn't and you have to turn it on then off then there is a problem in the brake circuitry signal to the console and you will have to replace the brake/microswitch assembly. Hope this helps
Posted on Mar 01, 2011
Testimonial: "will give it a try, thank you."
Scooter troubleshooting
Download the service manual from Pride's website. It has all the answers.
May 07, 2014 | Pride Mobility Revo 3 Wheel Electric...
My srtrider will only go for a few feet then comes to an abrupt stop its abit like the back wheels jam..but then it will go for another couple of feet then come to a stop again there are no warning lights...
If your batteries are running very low, this is the most likely source of your problems. 80% of my scooter repairs involve batteries. The fact that your scooter runs is a good thing. The fact that it runs only a few feet and gives you no error code when it stops indicates the electronics have no battery power to indicate a flash code. The back wheels jamming probably relates to a no power condition causing the brake to lock (it takes power to release the brake and turn the motor)
This scooter uses two U-1 batteries that last between 1 and 2 years. From your description, I would replace the batteries first and make any further determination of any problems, if any,after that. These batteries are available locally at a large discount (between $50 and $160 each) and can be installed with basic tools, saving you money on the labor charge.
Shop around for the best price. Charge the new batteries fully before use. Enjoy.
Hope this helps.
Nov 25, 2010 | Electric Strider Midi 4 Wheel Mobility...
TRITON #PL3-01 HAS NEW BATTRIES, BUT WILL NOT MOVE WHEN HAND CONTROL IS ACTIVATED. WHERE MIGHT PROBLEM EXIST.
mcdevito75 here, Most likely at the battery connection, are the battery--ies fully charged?? check connections at battery, and motor.
Jun 23, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
May 02, 2010 | Electric Mobility Mobility Electric Power...
Sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
Jan 04, 2009 | Golden Technologies Avenger 3 Wheel...
Pride Mobility Products Pride Mobility Celebrity X 3 Wheel Electric Scooter Logo
32 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
