Question about Samsung Refrigerators
Samsung Refrigirator RS2545SH: Installing my ice maker when I heard several clicking sounds, I realize I forgot to unplug my refrigerator before installing my new ice maker. After plugging back my Ref I notice that my front control panel stop working. Replaced it with a new one still no luck. Ice maker not working but everything else seems to be working fine. Do I need to replace the Main PCB PANEL? Help pls.
Posted by Tom Alba on
  • 1 more comment
  • Tom Alba Dec 13, 2012
    Thanks John, All connection seems to be intact.
  • John Tripp
    John Tripp Dec 14, 2012
    If you would like me to go over wiring and discuss testing with someone that you without charge please let me know. I am availiable in the mornings and evenings Eastern Standard Time. Thanks JT http://www.google.com/recaptcha/mailhide...
  • John Tripp
    John Tripp Aug 20, 2014
    Wow, you just now getting back with me? isn't the keypad separate from the dispenser control board?
John Tripp
  • Samsung Master
  • 4,656 Answers
First lets check the wiring plug under the top left hinge cover to insure the connection is firm and then check connections at the motherboard. Let me know what happens, Thanks Sea Breeze
Samsung Refrigerator Familiarization
Samsung Refrigirator RS2545SH: Installing my ice m - 12_13_2012_10_51_15_am.png
Posted on Dec 13, 2012
    Thanks John, All connections seems to be intact.
    My panel will eventually turn on after 2-3 hours after unplugging and this is how it looks like. None of the buttons work.
5 Related Answers
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Feb 13, 2008
Anonymous
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
Anonymous
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
Anonymous
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Posted on Aug 30, 2009
My ice maker model RS2545SH does not work I could not locate the reset button How to fix please
Have you checked the temperature, inside of the freezer? It must be at least, 0 degrees, before the water will freeze into ice. Is the ice maker getting power? Why do you need to find a reset button? I don't know your ice maker. I've never heard, of a rest button on an ice maker. Your question isn't specific enough. Other than that, I can't help you. Good luck.
Sep 07, 2014 | Refrigerators
I own a Frigidaire refrigirator model PLRS267ZA and the ice maker gets stuck / frozen mid ice making then starts to click because the gears can no longer turn. is there any way to fix this or do i have to...
It is best just to replace the ice maker. there are many small parts in the ice maker. You may be able to purchase just the gears but they are usually a factory order.
Jul 14, 2014 | Frigidaire PLHS267ZA Side by Side...
My Samsung RF265ABWP French door refrigerator has suddenly stopped making ice. I hear the old familiar noise it used to make just before I heard the ice drop in the bucket, only no ice drops. It sounds...
Is it getting water? If not, Most likely water valve is faulty and not letting water through, or feed tube through back freezer wall to ice maker is frozen which would be caused by dripping valve. It's either the valve or the ice maker not sending voltage to valve.
Nov 12, 2017 | Samsung RF265AA Bottom Freezer French Door...
I have a Samsung RF267ABRS french door refrigerator. It is two years old and it quit making ice. I have replaced the filter and the water dispenser works fine. I have also reset the ice maker. What can...
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Sep 03, 2010 | Samsung Refrigerators
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Frig Freezing EVERYTHING!
Your refrigerator has electronic dampers that may be only stuck. I think it would not hurt to defrost the refrigerator and lets have a look at those damper motors and see if they are responding to your control settings. Let me know, Sea Breeze
Jun 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Ice maker grinding sound
I found I get a odd clicking noise whenever the icecubes freeze inside of the box in the top left. You'll see about 20 little fingers, arms, or whatever you want to call them that spit out the ice into the container...make sure those fingers/arms arent stuck from the ice.
Jun 11, 2008 | Maytag MSD2651 HE Side by Side...
Ice Maker does not work
My ice maker jams up once in awhile. I use a hair dryer aimed at the mechanism on high. Avoid close contact air flow directly on plastic parts. Takes 2 to 3 minutes.You will hear machanism pop several times, then wire raise up and drop.
Jun 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
240 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
