SOURCE: YZF-R6 problem with headlights
this is normal for an r6. the lights are set up as endurance lights from the factory
SOURCE: engine idles fine with high beams on and bogs down with low beams
voltage regulator... just a guess, but better get it checked.
SOURCE: my high beam wont work on my yamaha xj600..
remove the bulb and test with a multi meter that you have power at the high beam socket. If so it is probably corrosion on the contacts. Clean with a plastic scourer and re fit the bulb. If no power there then test wiring for a broken wire or a dead relay.
