The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver butto
First, press and hold down Cancel and see what happens. That may reset the cycle.
or
The reset sequence is : 1) Crack the door open. 2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry 3) Close and latch the door 4) Press the cancel button (the circle with the triangle in it)
If clean light flashes seven times then
http://www.youtube.com/watch?v=Hv7xOaucH7I
Check this video for detailed explanation on what is the problem and how to rectify it.
1.Locate the
"Energy Saver/Dry" button on the dishwasher. The location of this
button will be different depending upon the specific model number of the
dishwasher, but should be easy to spot. If you have trouble finding it, you can
check the diagram in the manual of your dishwasher for the exact location for
your specific model. Press and hold down this "Energy Saver/Dry" button for
at least four seconds. Make sure that you do not release the button until at
least 4 seconds have passed, otherwise the lock will not become disabled. Check to make sure that the child lock indicator light has
turned off. If this light is no longer on, this means you were successful at
turning off the child lock. If the light is still on, repeat the process, but
try to press and hold the "Energy Saver/Dry" button for a few seconds
longer. If it still doesn't work, there may be a more complicated issue with
your dishwasher. Consult your manual, or call to the manufacturer or repair man
to determine if there is another problem with your dishwasher.
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
