Question about Garden
Cub cadet LT1045 starter solenoid: can 4 prong replace 3 prong?
Cub cadet provided me a 4 prong trombetta starter solenoid to replace a 3 prong. Can I use the 4 prong and if so, how do I wire it?
Posted by jim2241 on
Dwayne Kish
    New Friend:
  • 7 Answers
Yes you can. The small wire from the key switch goes to the prong closest to the power wire from the battery.
Posted on Dec 13, 2012
5 Related Answers
Mark Harnett
  • 115 Answers
SOURCE: The drive belt fall off
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Let me know how you made out!
Posted on Jul 19, 2011
Roger Geer
  • 78 Answers
SOURCE: How do you remove the front tire on Cub Cadet
Thats a plastic dust cap.Remove it very carefully so not to damage it. Then under the plastic cap will either be a Cotter pin or and E clip remove what is there and slid the tire and wheel off the spindle. These are a bear to break down and dismount and or remount. Unless you have a mini tire changer. I use my huge vise and a shaft the size of the spindle.I use motorcycle or bicycle tire irons. ITs a hassle believe me.
Posted on Oct 22, 2009
Anonymous
  • 109 Answers
SOURCE: Engine on Cub Cadet lt1045 stopped and now only
If this is Kohler engine...
and the battery is good, volts and amps...the compression release on the exhaust cam gear may be broken.
If so, the cam gear must be replaced
Posted on May 06, 2009
Larry Maranto
  • 198 Answers
SOURCE: Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
Posted on May 12, 2010
lnbn1975
  • 204 Answers
SOURCE: Cub Cadet LT1045 oil light
I am thinking that might be a notice to change the oil, which is only for notification purposes. Check your owners manual. There may be a procedure to reset the timer when you change the oil.
Posted on Sep 04, 2010
Cub Cadet won't turnover.
Try boosting it directly from the battery and see if it will turn over now. I had that problem and found my cable on the ground side had corrosion in it. I put new cables on and is ok now.
Jun 18, 2018 | Cub Cadet Garden
On cub cadet RZT 42 mower where do I connect the two ground wires to starter Solenoid
if it is 3 pole they will attach to the body with the solenoid bolt. if it is a 4 pole it will attach to one of the small studs.
May 19, 2018 | Cub Cadet Garden
How to put wires back on selenide
big from batt. on one side. big to starter on other. small wire will go to spade terminal to the key switch through a series of safety switches.
Oct 24, 2016 | Cub Cadet Garden
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Replaced starter dont remember how wires go back. the large red small red and the blue with the female slide on wires i know where they go but the larger blue one with the o shaped end i not sure if it...
you will have 3 or 4 wires to the solenoid. it sounds like you know where the 2 small ones go so the other 2 are for the battery and starter. one side of the solenoid will have a wire from the battery and the other side will have a wire to the starter. these 2 wires are larger because they carry the amperage required to turn the starter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Apr 16, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
Apr 11, 2012 | Cub Cadet Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
830 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
