The video at the link should help. You can alos download the repair manual free at the KIA owners site 2008 Kia Sorento 3 8L timing chain marks
SOURCE: Labor hours to replace timing belt on 2002 Kia Sedona
6-8 labor hours. But each shop defines labor hours differently
SOURCE: kia sedona outside door handle replacement
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Pull back the weather seal and you'll be able to get to remove the bolts securing the outer handle on
SOURCE: reprogram a keyless remote for my kia sedona 2006
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote, u will need t have the dealer do this procedure..
SOURCE: need to replace water pump in2005 kia sedona
The kia sedona water pump is an internal pump and needs to be replaced with timing belt service. if it is leaking, then you need to change the timing belt as well. probably not something you want to do in the back yard and will run you between 400 and 600 depending on your location and shop.
Visit my Blog
SOURCE: I need the diagram for
The Sorento has a timing BELT not a chain. Here is an image of the 3.5 litre engine & the timing marks. Note: special tools are required to hold the camshaft sprockets in place when belt is installed to prevent any movement....I hope this helps.
