Bought the car recently and everything was fine. Now the roof won't open and a red indicator is on inside, there is also a light come on the dash board when you turn the side lights and also the interior light won't go out unless you switch it to the right! Didn't have any of these problems to start with.
SOURCE: slk 230 komp
1. Try cleaning the front brake senor.
2. Replace brake switch (under dash).
3. Check front brake pads for wear.
SOURCE: '03 SLK 230 top wont close - stuck half way open
first thing I would try, disconnect the battery to the car for a minute, then reconnect it. that may correct your problem.
Testimonial: "Thank you so much! That was the fix no one (else) could give me on a Sunday. Now I need the code to unlock the stereo... I will check with Mercedes."
SOURCE: 98 mercedes SLK 230 ASR dash light on although
Check one of the fuses in the bonnet. There is most likely an electrical contact problem. You will need a fuse wire replacement
SOURCE: Can you tell me what the switch in front of the
hi believe it or not this is a programmable switch for your automatic garage door, i have a link for you and it will show you all about your car, just click link and away you go...hope this helps please vote thanks
http://www2.mercedes-benz.co.uk/content/unitedkingdom/mpc/mpc_unitedkingdom_website/en/home_mpc/passengercars/home/ownership/interactive_owners_manual.html
Testimonial: "Excellent prompt response - thank you"
SOURCE: electric windows are fine the roof gets half way
If the top is half way down that means that the trunk is open and should be touching the trunk switch to continue the process. The switch must be bad and it is inside the rear right fender close the the stop light
