There used to be an alert that would sound if I left my keys in the ignation or the headlights on. Now I find myself forgetting to turn the lights off and leaving the keys in the ignation! No fuses are labled for this problem in the fuse box. Any ideas?
SOURCE: 02 CRV:When my lights or keys alert does not tell me.
I had the same problem with the lights alarm on my 2002 CRV. The alarm is linked in to the door open switch on the drivers side. If you open the door, about half way down on the centre post you'll see a rubber covered push switch. This is held in place by a single phillips screw. Remove the screw and gently pull out the cover. On mine, the wires had become unclipped from behind and just had to be reconnected (push fit).
Apparently this is a fairly common problem caused by the seatbelt being caught in the door and catching the switch.
SOURCE: 01 Honda Accord LX: Which
Look under hood, under steering wheel, and on both sides of dash by doors.
