Question about Smeg A42C-5 Electric Kitchen Range
Outer cooking circle doesn't work
Got an issue with the bottom left cooking zone. Turning the knob past max and releasing doesn't work, the outer zone simply doesn't light up. (The inner circle also seems to be weak and not heat to maximum). The other zones all works fine, this one used to do just great up to a few weeks ago. Any suggestions appreciated.
Posted by Calle on
2 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Posted on Apr 04, 2007
Adrian
  • 109 Answers
SOURCE: SMEG SA410X-S heat not coming on for fan forced
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Posted on Jun 16, 2009
I don't know how to change the minutes on my clock. It's a jeep wrangler. I've tried holding in the time button and turning tune knob, doesn't work. Thanks!
is there a h/ m with two little holes any where on the radio? usually on the right or left of the clock. if so stick a paper clip into the hole and set. if not i would try the FF and the RW buttons
Mar 11, 2013 | Cars & Trucks
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
The air conditioner fan was working intermittently. It would come on and off. Now it doesn't come on at all. Cant' find the fuse or is it a relay?
Just replaced the blower motor on mine it is a real pain to do.Very expensive to have done.Motor is $200.00 at Auto Zone new,25.00 at the bone yard.If you have an electrical tester for dc voltage unplug the connector check center wire to outer wires while turning the fan speed cntrl up and down (+ & -) to see if you have power going to it,If yes you have a bad motor.Keep in mind there is power at outer wires all the time but checked one to another between the three you will only get power when the switch is turned on.I see this was 6 days ago,hope it helps.Blower motors are common problems with Cadillacs.
Jul 04, 2011 | 1999 Cadillac DeVille
Turning signals not working nor are flasher or hazard lights are not working where do i find the flasher box for turning signals
It is behind the fuse box. Follow the hood release line moving from the handle forward. On the left of the release line right before it starts to curve a lot I found two plastic 'cubes'. The bottom one with three prongs was the flasher.
Dec 04, 2010 | 1994 Mitsubishi Mighty Max
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Smeg A42C-5 Electric Kitchen Range Logo
56 people viewed this question
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
