Procedure for reolacing spark plugs on a 2007 4.6
It can be faulty or dirty spark plug itself. Also for reference get the fuel level checked. Is the fuel tank is empty or near to empty. http://alltypesofpartsreplacing.blogspot.com/2012/12/no-spark-faulty-spark-plugs-replace.html ---------- These will help. Thanks.
Try cleaning the spark plugs and then see if that is helping. On some cases the black carbon layer gets collected on the spark plugs and that causes the problem, so cleaning the plugs help. But if its not helping, then spark plug has to be replaced. Spark plugs get power from ignition coil to ignite sparks. If ignition coils are faulty then also there will no spark. --------------
To troubleshot and confirm the issue, I suggest you to go through the help link provided below, check the procedure and it will help you to confirm the issue in your case.
Click the link below:----
Click here to see how to replace spark plugs.
SOURCE: No spark?
Hi, common thing with the mazda was the coil or the ignition amplifier going faulty, both of which are located within the distributor, the coil ususally gives the symptoms you describe, a weak spark. The coil is the most common failure aswell for your vehicle i would recommend a new one, also make sure distributor is spinning as it could just be a case of a broken timing belt.
Good luck Davelee
SOURCE: tools required & procedure for replacing spark plugs
rachet long extension plug socket plug gapper ask parts store what gap should be its easy let me know hey vote for me ok
SOURCE: simply replace spark plugs - procedure?
pretty simple just screw them out and replace them you may need an extention with a swivel but you shouldnt have any major problems, remember to always hand start the plugs in the ports before using a wrench to ensure they are properly threaded.
