Will not go past 30 mph
SOURCE: 2007 chevy trail blazer low beam lights wont work.
maybe a fuse the fuse box is under the drivers side passenger seat . sometimes ive seem them get something spilled on them and i had to wiggle the fuses to clear the corrosion
SOURCE: 2005 CHEVY +TRAIL BLAZER ABS AND BRAKE LIGHTS ON
When the ABS light is on when driving there is a problem in the anti lock brake system and you will need to have it tested to find out what the problem is. As long as the light is on the ABS has been shut off by the computer until it is repaired. There could be problems with one of the wheel speed sensors, wiring or the ABS pump. On some vehicles the red brake light will come on too.
SOURCE: where is the pcv valve on the 2005 chevy trail blazer
Dear hispeed3,
If you haven't bought the part yet and are planning on replacing it ...i'd go to the auto parts store and ask them for the part location. They are usually glad to do this. I know Advanced Auto Parts does this for me.
Are you having a problem with your 2005 Chevy Trail Blazer?
If so...I'm here for you!
jack
Please Rate This!
It is located on top of the valve cover. Buy the new one and you will see what it looks like, then you will pull the hose off of it and put the new one on, 5-minutes at top to do this job.
SOURCE: M y radio stopped working on my 2004 trail blazer
The 2004 Trailblazer has two fuse panels, one in the under hood and one under the middle row seats. The radio fuse is marked RADIO fuse # 41 and is a 15 amp fuse located in the rear fuse panel. To access the rear fuse panel flip the seat behind the driver to the upright position, under it you can see the fuse panel and a diagram should be on the under side of the cover.
Good luck and hope this helps.
