We have it set for 6 rings and then it ask you to leave a message. Now, it the answering machine comes on after 5 rings and it says the greeting in our house but on the callers phone it says the "not accepting calls at this time???!!! I have a manual and tried different settings but nothing I have done seems to help. Thanks for helping!!!!
SOURCE: rings only 3 times then message
I did not see what model uniden phone you have. check here for a manual http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
SOURCE: "i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
SOURCE: one ring - noise like fax to caller, phantom call to receiver
Try unplugging all sets and call in. Do you still have a faxlike tone, like from an ALARM system or something else down the street?
SOURCE: I lost manual to 6.0. I have answering machine set
Here is the link to Dect 6.0 manuals. Select model and download.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Hope it helps.
