Specs: Processor : Intel Core i5 -2430M at 2.4GHz Memory : 3072MB Display : Intel HD Graphics 3000 (integrated) Nvidia GeForce GT540M 1GB GDDR3 (discrete) (in dxdiag, under the display tab, it shows Intel HD Graphics 3000 and the Device type as Full Display Device) 500GB HDD Windows 8 Pro 64-bit
Not clear to me whats really you wanted to do.
Are you trying to use HDMI cable to display on screen or using a wireless connection to display?
Well i can only suggest to try different cables if you just want to display it.
Hope this will helps.
-J-zon
Update to Windows 10.
I’m happy to help further over the phone at https://www.6ya.com/expert/danny_60b7cb5b0ffb2484
SOURCE: call of duty 4
Yes the game should run but at pretty low settings due to the graphics card :(
SOURCE: nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
SOURCE: GRAPHIC CARD PROBLEM
Hi, I noticed you posted this same problem again. Here's the answer from the first post which should answer your question.
