Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 315 MHz Security+ Universal Remote Conversion Kit Model 139
This conversion kit wires in a new controller to the garage door opener, and includes a remote with a preset code. I took it out of the package and installed it. It worked right away. THE PROBLEM - After I successfully added a second remote, using the pairing instructions (Skylink G5), the original remote didn't work any more, and won't pair.
Posted by lucasvanb on
3 Related Answers
Don Maggard
  • 3197 Answers
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Posted on Jun 01, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: I'd like to erase the present code on my Craftsman
On the back of the motor unit near where all those white wires go you will find a button. Press and immediately release that and then walk over to your keypad and enter a four digit code of your choice and press enter. You should be good to go.
Posted on Dec 30, 2010
Don Maggard
  • 3197 Answers
SOURCE: I have two Security+ 3-function
The remotes you have are on a different radio frequency. They will not work.
Posted on Jun 23, 2011
I bought a new Chamberlain garage door remote control (Model 953EV/EVC) but my garage door opener is date 1991. Can I get this remote to sync with it? I have one remote dated 1993 that came with the...
The 953EV/EVC remote is designed to work with garage door openers at 315MHz (more or less). Your older unit doesn't work at that frequency. I'm not positive but it could be 300MHz.
You need a retrofit unit to use the new remote. See https://aclickawayremotes.com/Liftmaster/355LM-2-315-Mhz-Garage-Door-Opener-Conversion-Kit/index.html for one that works with Chamberlain units.
I hope this helps.
(who has 2 pre-1993 garage door openers and two post-1993 units on various buildings. Yes, we run around with 2 remotes everywhere.)
Mar 13, 2013 | Home Security
I have bought a second remote control craftsman 315 918191 i have remote device install with my crafftsman door opener there is no learn buttom on either device what can i do thank you
Post the model number of your opener. It is on the end of the motor unit nearest the door. It starts with 139. Also post the model number of your new remote. It should also start with 139.
Mar 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/s HP 315 MHz garage door opener (Model 139-18470DM). The temperature here is currently 34 degrees celsius with the windchill. When trying to close the garage door from the main switch, the...
Check for some obstacle in the path of the light beam sensor that (should) be installed across the width of the door opening about 3-4 inches off the ground.
Jan 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Can a universal remote be used with Sears Model 139.664300?
Not just a universal remote but a universal remote control replacement kit can be used. It consists of a remote and receiver. It is available from Sears and the number is:
Model #00953751000
Jan 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
We recently purchased a home. The garage door opener is an older Sears Craftsman model : 139.53635srt1. The previous owners (who lived there about two years I think) did not use the keypad that is...
The conversion kit you purchased from Sears will work with any door opener and has the latest security feature but the bad news is your keypad will not work with it. If you want a keypad you must make sure it is 315 mhz and Security +. It would be Sears latest model.
Dec 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
129 people viewed this question
Top Sears Building Materials Experts
Mike
Terry Smith
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
