2.3 L 4 cyl 5 speed manual transmission spec plate on the firewall says it has the M75 transmission in it .
There
are many possibilities that can cause car to make noise. It's
actually from where the noise is coming from. Front end or rear end. From
engine area or from inside the steering or from brakes. There
is N-number of possibilities for the car to make grinding noise or any other
kind of noise. --------- For
step by step troubleshooting this problem, I suggest you to refer the help
links mentioned below. Its a complete solution with proper explanation to
identify the cause of problem: ------ Click
the link below: ----- ABS light comes on and Car makes Grinding noise? http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html ------------------ Car makes clicking noise? http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html -------------- Car makes whining noise like
driving on rough pavement? http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html ------------ Chirping Noise From Car? http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html ---------------- What are the possibilities for
Clicking noise in car? http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html -------------- Squealing at start up on car? http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html -------------- Chirping sound coming from engine? http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html ----------- Vehicle making Clunk Thump Thud
noise? http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html ------------ 4X4 Truck makes roaring noise in
the front end? http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html -------------- Heater makes clicking noise under
dash on Ford Explorer? http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html --------------- Clicking noise under dash and
front defroster not working? http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html ------------------ Car Brakes Making Noise? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html --------------- Car Alternator making noise? http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html ----------------- Car Alternator Bearing Makes
Grinding noise? http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html ---------------- Engine makes noise and Cooling Fan
belt Breaks? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html -------------- Vehicle Makes Clicking Sound While
Taking turns? http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html ------------- These will help. Thanks.
SOURCE: Need a new Transmission assy.
GT4x4 are probably your best bet, or alternatively breakerlink or breakeryard (google for them)
SOURCE: manual clutch
Sounds like the wrong pressure plate. I got a kit from Autozone and it was the wrong pressure plate. My old one was obviously thicker. With the new pressure plate, the shift fork was almost at full travel before any resistance. That's no good. I had to pull the transmisssion again and use my old pressure plate. Luckily, it was in good condition. Then, the clutch slack was easily adjusted and works great.
SOURCE: no clutch pressure on a hydraulic clutch system
look for leak....under the dash on the floor if its wet there its the master. Just follow rod from clutch peddle to master. Check the line and not sure if your slave is on the outside of the trans look there or if its in the trans see if its wet coming out of the bell housing (where trans meets engine) and replace that part and bleed system
RPO | Trans Name | 1st | 2nd | 3rd |
MNK | Allison 1000 | |||
MNZ | Allison 1000 | |||
MW7 | Allison 1000 | |||
MYB | ||||
MYC |
M74 | Allison 1000 | |||
M22 | 5L50-E | |||
M82 | 5L40-E | |||
MTW | Allison 2400 | |||
MX4 | Allison 2000 | |||
MX5 | 5L40-E with PTU* | |||
MV3 | 5L50-E with PTU* |
M30 | 4L60-E | |||
M32 | 4L60-E HD | |||
M32 | 4L65-E | |||
M33 | 4L60-E Hybrid | |||
M41 | 4L30-E | |||
M70 | 4L70-E Super Duty | |||
M99 | 2ML70 2-mode Hybrid* | |||
MD8 | ||||
ML4 | 4L30-E | |||
MN8 | 4L80-E HD | |||
MN8 | 4L85-E | |||
MT1 | 4L80-E | |||
MW9 | HM 200-4R |
M40 | ||||
M41 | ||||
M65 | ||||
MD2 | ||||
MD3 | HM-180 | |||
HM-200C | ||||
HM-350 | ||||
HM-400 |
MH2 | ||||
MH4 | ||||
MH6 | 6T75 (AWD) | |||
MH7 | ||||
MH8 | ||||
MY9 | 6T75 (AWD) |
Aisin-AW 55-51LE | ||||
M09 | Aisin-AW AF33-5 | |||
M43 | Aisin-AW AF23-5 | |||
M45 | Aisin-AW AF33-5 | |||
M98 | AF33-5 | |||
MJ7 | Honda 5AT | |||
MJ8 | Honda 5AT w/PTU* | |||
MLS | Aisin 50-40E | |||
MU3 | Saab 76.5mm |
MLQ | Aisin 81-40LE | |||
Aisin ZF 4HP 16 | ||||
HM 325-4L | ||||
Jatco JF405-E | ||||
M10 | Jatco JF403-E | |||
M13 | 4T60-E HD | |||
M13 | 4T60-E | |||
M15 | 4T65E | |||
M45 | Aisin-AW AF33 | |||
M57 | A245-E | |||
M76 | 4T65E with PTU* | |||
MD7 | 4T65E | |||
ME7 | 4T45-E BAS Hybrid | |||
ME8 | ||||
ME9 | ||||
MH1 | 4T80-E | |||
MN3 | 4T65E | |||
MN4 | 4T40/45-E | |||
MN5 | 4T45-E | |||
MN7 | 4T65E HD | |||
MS7 | A240-E | |||
MU4 | A246-E | |||
MU5 | U341-F |
M60 | GEO Metro | |||
MB3 | A131L | |||
MD9 | ||||
MX1 | A131L | |||
GEO Storm | ||||
HM-425 |
M10 | Tremec 85mm | |||
M12 | Tremec T56 | |||
ML6 | ZF S6-650 | |||
ML9 | ZF S6-40 | |||
MM6 | Tremec T56 | |||
MV1 | Aisin 85mm | |||
MV5 | Aisin D173 AY6 | |||
MV6 | Aisin 85mm | |||
MZ6 | Tremec 85mm |
M35 | Getrag 260 | |||
M35 | Getrag 260 (2003-2004 Cadillac CTS) | |||
M49 | BW 5spd | |||
M50 | ||||
M59 | GEO Tracker | |||
M86 | Getrag F23 75mm | |||
M94 | Getrag F23 | |||
M96 | Tremec 109mm | |||
MA5 | Aisin AR5 82mm | |||
MG3 | Getrag F23 | |||
MG5 | ||||
M50 | ||||
M51 | ||||
MH3 | Tremec T-5 | |||
MK5 | C59 | |||
ML2 | Tremec T-5 | |||
ML3 | Tremec T-5 | |||
MT8 | ||||
MU3 | Saab F25 | |||
MW2 | ||||
MW3 | NV4500 109mm | |||
TR-3450 | ||||
TR-4050 | ||||
TR-4050 | ||||
2007 Chevrolet Optra and Spark (Trans code Y4A) | ||||
2007 Chevrolet Optra and Spark (Trans code Y4M) |
M20 | HM-117 | |||
M73 | Isuzu | |||
MC0 | Getrag | |||
MC9 | ||||
MY6 | NP260 |
MT2 | Opel F40 83mm | |||
MU9 | Opel F40 83mm | |||
MTN | Toyota C60 |
D-16 (2005-2008 Chevrolet Aveo 1.4 DOHC / 1.5L) | ||||
D-16 (2005-2008 Chevrolet Aveo 1.4 SOHC) | ||||
Y4A (2007 Pontiac Matiz) | ||||
YM4 (2005-2007 Chevrolet Aveo) | ||||
D-20 (2005-2007 Chevrolet Epica) | ||||
L73 | Pontiac LeMans F16 | |||
M42 | Geo Metro | |||
M43 | AF23 | |||
M49 | BW 5spd | |||
M58 | Geo Metro | |||
M79 | LeMans F13 | |||
M86 | Getrag F23 (5T45MI) | |||
M98 | Aisin 55-51E | |||
MB4 | Geo Prizm 1.8L | |||
MB5 | Geo Prizm | |||
MFB | 2008 Chevrolet Epica 5-Speed S/R (D24) | |||
MFN | 2008 Chevrolet Epica 5-Speed S/R (D33) | |||
MG1 | HM-282 | |||
MG2 | HM-282 | |||
MJ1 | Isuzu | |||
MK7 | Isuzu | |||
MLM | Y4M (2008 Chevrolet Aveo 1.6 DOHC) | |||
MR3 | Isuzu | |||
MV2 | Chevrolet Sprint | |||
MY7 | Early J-car |
RPO | Trans Name | Lowest | Highest |
M83 | V20-E | ||
M75 | V25-E | ||
M16 | V25-E AWD |
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
