1997 Chevrolet Suburban Logo
A
Anonymous Posted on Oct 18, 2017
I have a 1999 suburban with a 5.7 vortec the engine wont build rpm while moving,but revs freely in nuetral or park.If the computer senses movement in forward or reverse the engine misses such as a rev limiter would do.Even shifted into nuetral while rollig to see if engine would rev up.It wouldnt rev till vehicle completely stops then revs fine
Rick M
Level 3:
  • Chevrolet Master 4,148 Answers
  • Posted on Oct 19, 2017
Rick M
Chevrolet Master
Level 3:
Answers
4148
Questions
0
Helped
1253246
Points
13941
The computer can't sense movement. An engine with worn spark plugs or bad coils can run perfectly fine at idle and begin misfire the second you put it into gear or under loads. Plugs/coils misfire most when under load. Have you checked them?
5 Related Answers
Anonymous
  • 65 Answers
  • Posted on Mar 23, 2009
SOURCE: 1991 Caprice No reverse. Moves in neutral. All forward gears OK.
shift linkage needs adjusting,,could be bent, easy fix, located along firewall to fram beneath the column, ask your son wut he ran over and didnt tell u about... hope i could help...:)
Anonymous
  • 144 Answers
  • Posted on Jul 24, 2009
SOURCE: car does not drive forward but works in reverse
Sad to say but your automatic transmission has bit the dust.
Anonymous
  • 62 Answers
  • Posted on Aug 02, 2009
SOURCE: No forward movement but reverse works fine. Help?
More than likely the forward clutches are burnt,causing the no forward movement problem.Remove the transmission dipstick and smell the fluid,if it smells like burnt coffee then you need the transmission rebuilt.
Anonymous
  • Posted on Jan 11, 2010
SOURCE: my 1999 chevrolet suburban will not go into
my 1999 suburban will drive forward but it will not bafkwards?
Anonymous
  • Posted on Mar 15, 2010
SOURCE: 98 tahoe 700R4 TRANS WONT SHIFT INTO REVERSE AND
take the pan off and check the reverse boost valve clip on the front drum and make sure the clip did not pop out of the groove. thats usually the problem or it can be your sunshell that either cracked or something.
Hyundai sante fe 2007 2.2crdi wont rev past 3000 rpm
If your standing still in park it wont rev past 3000 rpm as its got a limiter on it And only revs past 3000 rpm in drive on the move.
1helpful
2008 sprinter 2500, every time i start to drive I have no power for about 5 to 8 seconds nothing happening then slowly it starts to rev up engine and start to drive then its fine , there r no codes
Check the engine in neutral/park and depress gas and confirm engine is slow to rev up. If the engine revs in gear and little or no movement have the transmission checked.
this car is likely a drive by wire.(no cable between gas pedal and throttle actuator motor) Some one needs to observe the throttle to see if it advances when the gas is depressed.
The simplest analysis would be the connection to the engine computer with not a simple scan tool but a Chrysler proprietary analyzer to see the interaction of throttle position and engine RPM
Hope this helps?
2002 jaguar xj8 when I drive it won't go over 3000rpm
Jaguar wont rev 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > wont rev 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... Wont go beyong 3000 Revs s type 2001, wont go beyond 3000 Revs and it' in limp ... Question about 2002 X-Type ... My jaguar xjr8 year 2000 battery went dead started car went for short drive back ...
Jaguar engine cuts 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > engine cuts 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... engine cuts out and shudders at 3000 rpm won't accelerateobd code p0332 2002 jaguar x type 3.0 l P0332 - Knock ... Car is boging out in park and will not go over ... driving, don't worry about it.
Rev Won't go up
www.jaguarforum.com/showthread.php?t=14662
Engine wont catch
Catch?
cranks fast
starts every time.
idles fine hot or cold , or both? hot idle not too fast.
i race engine , in park and neutral, I can hit 3500 rpm easy, can you.
i release brakes, (brakes are not packed in ICE , are they?)
I select 1gear or reverse (A/T or m/t)
the car moves or dont move, which is it, my guess catch = no move at all.
I try to drive, i look at RPM and MPH
RPM moves up and MPH track.
track means they both move in a linear progression.
RPM rises and for all RPM increases MPH also increases.
does it?
if all that works then we have an engine power issue.
weak on hills?
2answers
Can rev up the RPM,s in nuetral but it will only idle when its in grear.What do u think
Your car is probably in the limp mode meaning it won't allow you to rev the engine with it in gear. I suspect something majorly is wrong with your tranny. Limp modes are put into effect when you car senses trouble so it may still be fixable without too any $$$. When was the last time you serviced the transmission ( oil and filter change?)
Wont move in drive.but if you put it in nuetral and rev the motor to1200 rpm and dop it in drive it works fine until you stop again
oil level low ,start engine ,handbrake on then select reverse and then check oil level ,think you are about at a least a litre short
1helpful
2answers
How do you remove the rev limiter in an 02 impala?
the rev limiter is not a part, it is built into the programming of the computer that runs the electronic fuel injection, some of the more popular performance cars can be programmed to change the rev limiter paremeters with after market software and modules but not this one, no one makes anything for this yet.
1999 ford windstar sensor problems on 3.8 engine
iac valve is sticking remove valve and clean the shaft so it moves freely. This is a very easy fix.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
