I run a HDMI from my computer and it plugs into a DVI-D on my monitor, and my screen resolution i 1680x1050, 60hz refresh, and whenever I press the auto adjustment button it says Auto Adjustment not available. I don't see why, there's a button for it, so i know it's a feature on the monitor.
I looked up your monitor and that resolution is not supported. Which means auto adjustment will not work.
The video card will compensates for that, and resizes the picture for a display resolution that shows the picture anyway, (if it can) but isn't what you wanted. Your best bet is to use resolutions that are compatible, or get a (different) monitor.
SOURCE: auto adjustment?
Press and hold the Menu button until the menu disappears - and you're OSD will magically unlock.
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
SOURCE: screen flickers in 1680x1050 - samsung 2232BW plus
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
SOURCE: Acer x223W Monitor issue - not displaying correctly in native resolution
hi, when all connected press and hold the FN key on the bottom left of the keypad while pressing one of the function keys F1 to F12(the one with picture of a screen or monitor). You may need to press it more than once but if will eventually switch the display over to the tv
Hope this help
