Fisher & Paykel Astro 1.5 double oven (B1452)
Bottom oven fan element not working. This is a circular element that sits around the rear fan. Pulled element out thinking it had gone (after only 2 years seemed qucik - other elements working). When finally got element clar of hole discovered only one wire connected (white solid size wire). So fished around in rear hole and pulled out a few wires. But only one of them loose with appropriate spade connector- HOWEVER it is a thin blue one. ie I expected a matched plain white wire to the other wire connected to element.
Before rushing in and shorting anything out can you tell what the other wire to the element should be (apart from green earth).
Thankyou
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Check the Heating Element of your Oven.......
SOURCE: I'm changing the broil element
Hi Please check this video if you want to replace broil element
yourself: Hope this helps...please post back for further assistance. Daniel
SOURCE: I have a fisher &
Hi - theres a few components that may well cause this to happen - the power module which controls the heating & fans etc - isolating relay which switches the heater & fan relays - it only avctivates when a cook mode/cycle is selected.
One of the two components could be faulty - I guess a sparkie or techie may be your best option..
I found the fan element had burnt out so bought a replacement.
There was two blue wires connected to one spade connecter, one blue wire connected to a spade connector and an earth connected to a spade connector
The earth is self explainitory and connects to the centre connector and connected the other two to each end of the element - yet it still will not work.
Any ideas ?
thanks
