Ovens Logo
Janet Edwards Posted on Jan 20, 2018
Neff oven dial symbols
I have moved into a new house and although the two Neff ovens are wonderful, the previous owner didn't leave a Manual/Instruction Guide. Can you let me know please what the symbols mean. I've worked out the fan, grill, but there are quite a few I don't know. Thanks. Janet
5 Related Answers
Anonymous
  • Posted on Oct 15, 2008
SOURCE: neff b1421 single oven
my oven is not reaching the required temprature what could the cause be please
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 25, 2008
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Anonymous
  • 44 Answers
  • Posted on Mar 19, 2009
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Feb 07, 2010
SOURCE: Have had 4 Neff oven elements in 2 years.
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
2coolrick
Cool Blue Services
  • 560 Answers
  • Posted on Jun 05, 2010
SOURCE: Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Bulb blown on Neff Oven model B16P52N3GB - zero ohm resistors or not?
Resistors are color coded , 4 5and 6 bands , google resistor color chart , by checking the chart you should be able to replace them with exact part .
Aug 16, 2021 • Neff Ovens
I have a new neff built in oven. I turned it off over an hour ago and the fan is still running. Surely this is not right. Any suggestions.
Hello, Sylvia -
Since your Neff oven is new, I hope I am correct in thinking you have the owner's instruction manual for the oven and you already checked there to see if there were any troubleshooting tips regarding the fan still running after turning the over off over an hour prior.
If you do not have the instructions for the new oven, check here:
http://www.neff-home.com/uk/service/manual
Note: You will need to supply the E-Nr number for the oven. If you do not know where to find the E-Nr number, on the web page cited above, click or tap on the link for the rating plate finder.
After checking the owner's instructions for the oven, the next thing I would suggest is contacting Neff Specialist. See the information here:
http://www.neff-home.com/uk/service/support
Talk to a Neff Specialist.
You new Neff oven is most likely still under warranty.
Best wishes.
May 01, 2018 • Neff Ovens
Power supply
it doesnt come with a cable it has to have its own 25 amp cable from your consumer unit or previous oven installation.
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
1helpful
3helpful
RECENTLY MOVED INTO A NEW HOUSE WITH A NEFF DOUBLE OVEN (OLD ONE). THE CLOCK IS FLASHING ALL THE TIME AND NOW THE MAIN OVEN WONT WORK - CAN YOU HELP PLS
Your oven might need to be reset first before it will work again normally.
The most common reset for NEFF double oven is to press and hold down the two arrow buttons while turning the small knob
Try it!
Oct 04, 2010 • Ovens
5helpful
2answers
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
1helpful
Hi
regards dan
3helpful
Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
2helpful
Looking for installation instructions for a Neff B1691 oven
Neff have some downloadable installation instructions at www.neff.co.uk select neff owners, then customer service, this opens a new window which has instruction manuals as an option, select this and then enter an E number for the model ( i tried B1664) a similar single oven and this brought up a pdf file. At the end p67 it gives cable sizes and types and connection details which should give you what you need.
Please remember to rate this solution.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
