Question about LG Flatron 775FT 17" CRT Monitor
Vga cable problem - LG Flatron 775FT 17" CRT Monitor
Posted by vinoth on
saadullah
    New Friend:
Step 1:
vga cable 9 wirs corict conniction
Step 2:
i need schematic digram of vga cable of lg t730sh
Posted on Feb 09, 2013
I am receiving a CABLE NOT CONNECTED error when I connect my vga monitor to my laptop using an VGA to HDMI cable
If you actually have a cable with HDMI on one end and VGA on the other, it will probably not work. HDMI uses a digital signal and VGA uses an Analog signal, there needs to be some circuitry somewhere that handles the conversion. You are probably getting Cable Not Connected because the monitor is scanning for an Analog signal and not recognising the digital signal coming in over the VGA port.
Get a HDMI to VGA converter
Jan 22, 2017 | Vga Computers & Internet
Connect aspire v5-552p to tv
It depends on the ports the computer and the TV have
If both have VGA (blue) use a VGA to VGA cable.
You can also use an S-Video-to-S-Video cable
If both have DVI, use a DVI-toDVI cable.
If both have HDMI use an HDMI-to-HDMI cable.
Other possibilities are combinations of the various modes above VGA-to-DVI, VGA-to-HDMI, VGA-to-S-Video, etc.
VGA-To-D
Nov 07, 2013 | Acer Aspire Computers & Internet
How do i hook my compaq preario cq56 laptop to my hitachi hd plasma tv
The laptop looks like it has an external VGA port only and without knowing what model of Hitachi tv it is. It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
1. VGA to HDMI cable: http://www.amazon.com/Video-Cable-Black-Support-Necessary/dp/B002TUC64W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697785&sr=1-1&keywords=vga+to+hdmi+cable
2. VGA to RGB cable: http://www.amazon.com/eForCity-Premium-Component-Cable-Black/dp/B0012SPNII/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697879&sr=1-1&keywords=vga+to+rgb+cable
If you do not have an HDMI input, you will also need to get an audio cable as well. Standard mini-stereo audio cables should allow you to connect the laptop to the tv.
Dec 16, 2012 | Compaq Computers & Internet
What cable do I use to get a G0773 Graphics card (Dual VGA/Single Port) to work with a single Acer P215H Monitor?
check vga cable or VGa card for enhance of video for more tips sign in ghulam rabani
Oct 23, 2012 | Dell G0773 Video Card
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
What type of cable do I need to connect my macBook Pro to a Dell DLP MP1200?
You should be able to use a USB - 4 pin mini-DIN cable with this projector.
Mar 01, 2011 | Computers & Internet
I want to connect my laptop to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT. Before, I had a cable VGA-HDMI,...
I want to connect my CPU to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT.
Before, I had a cable VGA-HDMI, also no signal ( analogical & diginal ).
If I buy a cable VGA ( for CPU ) and 3 jacks ( green, blue, white ) for Component IN; does-it work ??
I need some help.
Dec 23, 2010 | LG Televison & Video
LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
May 28, 2010 | LG W2361V-PF 23 in. Widescreen LCD Monitor
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Feb 24, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
LG Flatron 775FT 17" CRT Monitor Logo
80 people viewed this question
Top LG Computers & Internet Experts
Ekse
Troy Staley
Troy Staley
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
