What is the default ip address for powerconnect 5212
Dell powerconnect 5212
Posted by mrjiyana on
Richard Thomas
    New Friend:
  • 26 Answers
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. what is the default ip address for powerconnect 52 - notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Posted on Dec 06, 2012
1 Related Answer
G Singh
  • 79 Answers
SOURCE: IP address
your voip enabled phone uses dynamic ip addressing so doesn't have a fixed ip. however if you want to configure the phone Connect the WAN port of the SPA922 to your network (router, switch or hub). Make sure that you have a DHCP server so that the SPA922 will get the IP address.
To login to web based administration follow the steps
Access the web based setup page of the SPA922. Verify the IP address through the LCD. Click Menu then press 9. It should show you the DHCP IP address. Open a browser and type that in the Address bar.
Click Admin Login .
Note: The SPA922 does not have a username and password by default. If you are asked for a username and password and you have not configured a password, it means that the SPA921 is locked by your VoIP provider. You need to obtain the password from your VoIP provider.
if this helps resolve your issue please vote for me. thank for using fixya.
Posted on Aug 10, 2009
Default ip
The PowerConnect 2224 is an unmanaged switch. As such, it should not have an IP address at all.
May 06, 2013 | Dell PowerConnect 2224 (0M4575)
By default there isn't one you need to use the serial cable and hook it up the console port and log into it with a terminal program such as hyper terminal or putty
Nov 26, 2012 | Dell PowerConnect 5212 (p5223np)
I have a Dell router(?) 2224. I want to go wireless in the house. Can I use this piece of equipment somehow or do I need to buy a real wireless router. Also att says i have to buy a motorola wi-fi...
if you product in the picture Dell PowerConnect 2224 that's a switch. att gives you a modem which you connect to router (wired or wireless) any brand you don't need theirs. then connect to switch (for wired connections) your will have to configure the router they might not help if you don't buy theirs
Feb 26, 2018 | Dell PowerConnect 2224 (0M4575)
How do I get into a terminal session on a dell power connect 2124 switch?
Hello Jlhambric.
The Dell PowerConnect 2124 is an unmanaged switch. Plug and play with no interface.
Feb 25, 2011 | Dell PowerConnect 2124 Networking Switch
I can not log onto my dell powerconnect 2708. I'm connecting the dell powerconnect 2708 into a hughes net modem and routing to three different locations. I would like to monitor/contol usage...
The problem you have is unlikely to be related to your server but to the modem and any ISP restrictions placed on your service i.e. it may block remote access or any port 80 traffic not originating from within your LAN. I don’t know much about your situation but it may be worth contacting your ISP to see if the functions you require are available with your hardware and contract type. Attached is a link that may help.
http://www.dslreports.com/forum/r19028526-Networking-Port-Fowarding-using-the-HUGHES-NET-Modems
Jul 02, 2010 | Dell PowerConnect 2708 8-Port Gigabit...
Dell powerconnect 2016 seems to have stopped working
most likly a failed power supply on the switch
look at the front of the switch look for leds,.......
if you see nothing and the power cable is plugged into a hot outlet than
go down to your neerest comp store and buy a new one
Apr 26, 2010 | Dell PowerConnect 2016 (pct2016)...
Remove a ACE from an ACL using CLI
Sure thing:
First to enable the web interface, try command:
ip http server
Also try:
ip http port 80
That will enable it on the default port
As for the ACL's I looked at the documention and I believe the syntax is to put a deny in front of the command and that will remove it.
Of course the GUI will be easier to deal with
The manual can be downloaded from:
http://support.dell.com/support/edocs/network/pc6024/en/index.htm
Jul 14, 2009 | Dell PowerConnect 6024 24x1000 Mbps...
Static ip address to dell powerconnect switchport for backbone
try for 195.9.200.00 - 195.9.200.32 series hope it will works
Mar 23, 2009 | Dell PowerConnect 6024F (p624fnp)...
Computers & Internet Logo
1,230 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
