Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
Have 2 behringer europower ep1500 poweramps 1 for sub, 1 for monitors, run the mains off the internal poweramp in board. But have several outboard effects dual 31eq, sonic maximizer, crossover, comp/lim/gate, quadraverb. Also what order from bottom up to place racks, and do I just patch each to the next on up til into the board? Wanna run mono.
Posted by ttguns469 on
  • ttguns469
    ttguns469 Nov 26, 2012
    As I stated, I run my mains off the rear plugins on the board using the internal amp for those, I run my sub thru the EP 1500 2x700 amp then into the crossover and on up through the rest of my racks then into the board. My monitors will plug into my other EP 1500 2x450 amp. Wondering in what order should my racks be, and how to tie it all in with which plugs. The user manual for this mixer is too basic,and doesnt diagram other than speakers or instruments straight into a channel. No mention of outboard gear or external amps being used and how to plug system.
John Malcolm
    New Friend:
    Problem Solver:
  • 13 Answers
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Posted on Oct 25, 2017
1 Related Answer
Fred Yearian
  • 5603 Answers
SOURCE: How can a PMP 2000
No you can't quite do this since the EQ's are right before the power amps in the signal flow. The monitor output would drive two 8 ohm speakers daisy chained at roughly 300 watts RMS... I can't imagine needing more than that for a venue that is within the capabilities of this unit.
You can drive both power amps by the monitor output by setting the mon/main function on the switch and using a short TRS cable jumper between MONITOR PREAMP OUT and the RIGHT POWER AMP INPUT jack. Drive your mains from the LEFT PREAMP OUT. The EQ's will ONLY affect the monitors. Use an external EQ if you need to EQ the mains with this connnection. Use TRS balanced cables to the main amp and CONNECT all interconnected equipment to the SAME power source or receptacle, even if it means running an extension to the mixer.
Posted on Apr 05, 2011
Testimonial: "This imformation was very helpful!"
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
I have a mackie cfx12 mixer. I just added an eq with sub woffer crossover via the main inserts using the proper insert cables. System works great, however when Using a CD player the subs will not work. any...
Sorry, I have looked at the schematics and the TAPE IN jacks are mixed into the MAIN outs AFTER the insert jacks, so your subs will NOT receive signal via the insert from the TAPE IN jacks.
You could make a small passive mixer merging the TAPE/CD before going to the crossover. This would require some non-standard cabling.... The other option is to run the CD into a regular stereo channel rather than the TAPE IN jacks... then the CD will go through the insert/crossover and to the subs as you desire. The last option is to use the crossover at the MAIN outputs instead of as an insert... which would be the CONVENTIONAL way... use BALANCED cables wherever possible.
Jul 22, 2011 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
I have a peavey 1220 powered mixer and I'm trying to hook up to two sp15's top's and 2 18; peavey subs for my band and I can't get the bass seperated so it's out of my tops
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
Jun 29, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
I have a A&H GL2400 - 32 ch.Console; How do i hook up (5) Effect units to the Console?
Is this for live sound? You can use your aux outputs as sends if you're not using them for monitors and return to spare channels. If any units are being used for only one channel, either run them in-line (use the effect unit's wet/dry settings) or use the channel's direct out and return to a spare channel.
If one effect is applied to several channels you could put those into a sub group, take that sub output to the unit and return the 100% wet mix to a spare channel.
Be careful not to send the return channels back to any auxiliaries you're using for effects.
Jun 18, 2011 | Allen & Heath Allen and Heath GL2400-32...
I have a peavey 8600 powered mixer. If i run powered speakers through the main output on the front will I not have effects?
If you run the speakers FROM the main you should have BOTH the effects and the EQ invilved with your signal.
Apr 20, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
How can a PMP 2000 be patched so that both internal amps are used to power the monitors, and the mains are sent from the mainpre-out to another power amp, while using one internal eq for the mains, and the...
Apr 05, 2011 | Behringer PMP2000 800 Watt 10 Channel...
Where on a 16:2 allen heath wizard would you hook up a 482i sonic maximizer?
The answer all depends on what you want to achieve.
  • If you just want to enhance the sound of 1 or 2 instruments / voices you could take a signal out from an individual channel on your mixer using the direct out and insert jack sockets on that channel however this may make it difficult to control in conjunction with teh E.Q. controls on that channel as the Sonic Enhancer would be pre-fade and pre E.Q.
  • Alternatively you could send several mixer channels of your choice through the Sonic by using one of the sub-mix outputs to give a feed to the Sonic, returning it to the main mix either via a couple of spare channels, or the paired stereo inputs that are only routed to the main outputs.
  • Thirdly you could use one of the auxiliary sends to allocate different levels of signal from any number of channels to the Sonic. These are normally used to supply a separate mix to on-stage fold-back systems, monitors etc. Here I would use one of the 2 post fade ones rather than the pre-fade - to avoid negating what you have set on the main mixer e-q (tone controls)/. One advantage of this option is that it allows you to only enhance part of the signal from a particular channel and to allow part to bypass the Sonic without enhancement. I think that this would be my preferred option unless all the auxiliary feeds are needed for other purposes.
  • Lastly you could just put the Sonic on the main outputs of the mixer. This would mean that the same level of enhancement would be applied to the whole mix. As the Sonic Enhancer only has unbalanced (mono) jack sockets this later option does reduce the likelihood of you introducing unwanted radio interference to the system, compared to putting it at an earlier stage in the mix because, as the Sonic is unbalanced, everything else after it in the mix chain will also be unbalanced.
Feb 02, 2011 | Allen & Heath Allen and Heath WZ3144 14...
I just bought one last night. I love it so far. I really don't no how to use it. My first question is how do I connect my monitors.? My next one is how do I use a mic. I have tried with the xlr input and...
http://www.behringer.com/EN/downloads/pdf/1622FX_P0557_M_EN.pdf
there is the manual
But to actually answer some questions for you as well.
1. How do I connect it to my monitors?
Out of the back of the console there is a Main Out : Left and Right. there are two sets, one is XLR, second is 1/4 in. Run those to Powered Speakers and Voila.
Note: If you are using unpowered speakers then you will need a poweramp to run speakers.
2. and 3. first make sure your fader is all the way down
Once you plug in your microphone the top white knob is your gain preamp actually turning your voice going into the board up.
Second set your Main Mix fader: far right faders to 0. Then, the channel your microphone is on bring up the fader and you should start hearing some of your vocal through the monitors.
4th. At the Top right there are two sets of stereo ins (RCA) all you need is a 1/8 in to RCA cable coming out of the Headphone/Line Out of your computer.
Good Luck, Cody J.
Dec 16, 2010 | Behringer XENYX 2442FX Mixer
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
119 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
