Water keeps collecting in overfill pan.
SOURCE: Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
SOURCE: Overfill Protection tripped on ASKO D3112 dishwasher
remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
SOURCE: ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
SOURCE: how can we get to the base pan in our asko d3350
if this is an under counter unit you will need to remove the unit to gain access to the sides where you may be able to drain that base pan. some of these fancy things require you to remove the side panels to get to that pesky base pan..
hope this helps,
best of luck,
ttfn
