Question about Biostar P4M80-M4 Motherboard
PATA port can run my Hard drive only but DVD ROM is not responding.Why?
I changed the cable several time but when I plugged the three ports in three channel its not working. But when I try to run either DVD ROM or HARD drive then its working. Is it a problem of the cable or mother board.
5 Related Answers
Anonymous
  • 1383 Answers
SOURCE: I need a usb 2.0 driver for my biostar U8668 mother board
when u power up the computer press "del" or F2 kewy to tenter in bios then go to usb configuration then set high spped in usb 2.0
Posted on May 06, 2009
Anonymous
  • 138 Answers
SOURCE: The ATX power supply on my computer went out, so I
Try refreshing all connections to the motherboard. Also clean the RAM as shown in the image below.cfaa97e.jpg
Resetting the CMOS may also help you in the process. Make sure that the power cable connected to the power supply is disconnected. Change the jumper settings of JCMOS1 (labled 1) from 1-2 to 2-3 for approximately 10secs. (refer to the image below).
Then return to original settings (1-2). Hope this helps.
Posted on Oct 07, 2009
Fred Yearian
  • 5603 Answers
SOURCE: Printer port not working
Set the BIOS via the setup before it boots to the "ECP" printer port configuration.
Posted on Mar 01, 2010
montesmack
  • 87 Answers
SOURCE: I have a Biostar TF715OU-M7
As far as your board being compatible I think you should be ok.
The BIOSTAR.COM website does show support for Vista 32/64,
but not windows 7. I would still attempt it.
Any driver windows 7 cant handle might be covered with a driver for Vista from biostar or found on the web as a fix.
there is a chance that it wont work though,maybe an important driver just wont work (doubtful but there is a chance).
If you Click the Blue "Manual" Tab on this page you will see a prompt to download "N73UA-M7T_N73PA-M7T_080104_B.exe"
I just downloaded it and extracted the files from the .exe file and it contained Two PDF files one 61 page motherboard manual and a 42 page bios manual.
On the driver tab you can find a driver for your IDE chipset top of the page you'll have to try the vista one.
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=305
My Norton NIS 2011 said the exe was clean.
If you right click the exe after it's downloaded you might be able to choose extract files {where you choose} and then you won't have to run the exe.
I use 7zip here http://www.7-zip.org/download.html. It will handle all your zipping and unzipping and its free.
But I did run the exe for the manuals just to confirm I wasn't sending you bad links. no problems, it just created the folder in the same folder it was in.
Let me know it this helped you or not.
Post your answers as a comment or reply and I'll be notified.
Cheers
Posted on Feb 08, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: My mother board is not
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on Apr 01, 2011
I have a GT4016 Gateway Desktop. I want to purchase a 2Terra Internal Hard Drive. Would this be a Sata or Pata Drive
If the computer is already open its easy to tell if you have SATA or PATA capabilites. Most modern computers have SATA and maybe one PATA. An SATA plug looks like a sideways L. The PATA ports have a couple rows of pins and require a cable ribbon. If you have both kinds of ports you should go with the SATA because this has a much higher bandwith (1.5 Gbps I think)
Aug 18, 2011 | Gateway GT4016 Desktop PC
I cannot see the partitions in (my computer) I cannot see the hard drive in the bios
Hell,
If you use desktop pc change the pata cable or fit you old cable tightly.
If the problem is same .remove the cmos battery and install it again.and set bios load fale save default.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 16, 2011 | Computers & Internet
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
I need to hook up a CD drive to my computer. I have a P5GC MX/133 mother board, two 256 gig hard drives and 3 1/2 disk drive. I would preferr not to diconnect any of the ubove
Hi kbrotzel,
You didn't indicate if your Hard drive is a SATA or PATA. So, I'm going to assume the problem your having is that the drive is a PATA, and your trying to install another PATA drive, when the board only comes with one IDE slot for PATA style drives. What you need to do is to exchange the CD ROM drive for a SATA drive, so you can put it in one fo the SATA ports. If they are both SATA, then just plug it into one of the SATA ports.
Good Luck
Mark
Nov 22, 2009 | ASUS Computers & Internet
Sata dvd rom cause the computer to crash, is it because its plug in to the wrong plug in on the board or the sata on the motherboard isnt the right one im trying to install a sata rom on a gateway 5474,...
on pata ,flate data cable use in long connerter . on sata cable we use thin and flatcable join in n small squire port. some bord have both type port we can use diffrent port in same time . but port should be good. i think there no chance to join different connecter joining. we look seriously. in any coonater we saw cuttin g shape or male female shape. power cable of smps which join in hdd/cd room may be lose when we join any part it can be short so connecting any cable before we do switch off or pullout powercable.
Nov 05, 2009 | SuperMicro LiteOn SSC-2485K - Disk drive -...
Samsung cd-master 40e will not boot
Is this conected to the motherboard vis sata or (ide)pata?If sata did you put it in the correct port and if so is it enabled.Secondly if ide or pata is the port enabled in the bios or do you have a second device attached to it.If using ide pata one drive should be master or slave ,,, or cable select.
These are the answers why it might not work.The last answer is it died,but i think this is the least likely answer.
good luck
Sep 17, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
Issue Installing 4th Drive Device (2 DVD Drives and 2 Harddrives)
You cannot plug an IDE ribbon in the floppy slot (port). The total IDE drives you can install is four (4). But check your jumper configuration. The DVD & DVD/CD-ROM cannot have the same jumper configuration to share the same IDE slot. One has to be MASTER (MS) and the other SLAVE (SL). Or you may put both drives on CABLE SELECT (CS).
Apr 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Where do i plug in a second hard drive on the motherdoard on a hp pavilion a1220n
When you open up the casing (make sure you ground yourself), there should be a ribbon cable marked master and slave. The master is your primary drive, so you would connect the slave to your secondary hard drive. Have any other questions, let me know
Nov 25, 2008 | HP Computers & Internet
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Biostar P4M80-M4 Motherboard Logo
Top Biostar Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Roy May
Michael Thomas
Michael Thomas
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
