Question about Ovens
Electrolux oven error code f 136...what to do?
  • Official Brand Answer
  • 4,342 Answers
Hello - Could it possibly be error code F13 or F36? According to my research this manufacturer does not have an error code F136. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and see if the error code clears. If it proves to be ineffective, contact a professional to move forward accurately to properly diagnose the unit.
Posted on Nov 27, 2012
3 Suggested Answers
Anonymous
SOURCE:
opstud
SOURCE: Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
Posted on Jun 07, 2008
SOURCE: i have an AEG Electrolux oven D8800-4 double oven
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
Posted on May 12, 2010
Electrolux oven error code f130.what to do?
Hey Luciano, I appreciate your inquiry!
From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
Nov 29, 2015 | Electrolux Ovens
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Jan 10, 2015 | Electrolux Ovens
How do I fix Error F 11 on Electrolux wall oven E30EW75ESS2?
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 08, 2013 | Electrolux 30" Built-In Single Electric...
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Sep 10, 2012 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux E30EW75E PF code will not clear
that code is letting you know that a power failure has occurred. try unplugging and shutting power off for a few minutes. if that error code still comes on, you may need to replace the control board
May 05, 2011 | Electrolux E30EW75E Electric Single Oven
Error: F 10
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
May 11, 2010 | Electrolux ICON Designer E30SO75ESS Oven
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
Hope I helped.
May 06, 2010 | Electrolux Ovens
May 27, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
2,570 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
