Question about Altec Lansing VS2121 Computer Speakers
Altec lansing 121 speaker wiring diagram - Altec Lansing VS2121 Computer Speakers
5 Suggested Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: wiring for Altec Lansing avs500
Hi, from a very old Altec ACS48 : Green - right speaker Red - left speaker Black - common, ground White, Yellow & another Black - power switch Orange - Led indicator Below is the pin layout
Posted on Jul 30, 2007
Anonymous
  • 17 Answers
SOURCE: Lost set up disc
go to the website of the company and just simply type the model no. u will get all the details and u can download a cd content too.....
Posted on Dec 03, 2007
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: installing the wires in the right place
Hello there!
First things first!
http://www.altec-lansing.com/downloads/ACS451_MAN.pdf
Posted on Feb 25, 2008
Anonymous
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
I need a wiring diagram fo computer speakers,Altec Lansing Multimedia FM501011854B
You mean the internal schematic, as in diagnosing / repairing a fault?
Google is your friend.
Look in images section of your browser after entering "altec lansing FM501011854B, schematic".
OEM's / Original Equipment Manufacturers as a rule usually don't post full circuit diagrams of their products on the web, to avoid competitors pirating their products.
But you may come across the schematic on a site that stocks service /repair manuals.
Otherwise search for Altec Lansing (Consumer Electronics) website.
Oct 13, 2017 | Audio Players & Recorders
Altec lansing 9 pin din schematic diagrama
try phone app called electrodroid its at google store free app showing pin diagrams ,that might help
Mar 25, 2016 | Altec Lansing Audio Players & Recorders
I need a circuit schematic for Altec Lansing amplified speaker system 121
You can always try the manufacturer but I would not hold my breath. Try to google it - that is a better choice since perhaps others have also had hassles and ................
Aug 09, 2015 | Altec Lansing Audio Players & Recorders
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
Wiring for Altec Lansing avs500
Jun 24, 2007 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
110 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
