I get a message "Paper Jam" there is no jam but the print cartridges will not move from the right. I went through all the suggestions and cannot move them manually.
Is there any reset buttons or anything of the sort? I have never had a paper jam on this printer and it worked fine two days ago-I wanted to replace the print cartridges and it will not move.I am 85 and on a fixed income so this is very important to me ( to be able to do what I can).
Paper jams can occur in 3 places: Entry, registration and exit.
If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
I'm not sure if you tried this, yet, but try the following link from canonusa.com website regarding clearing paper jams. Click on 'clearing paper jams inside the printer' on the page:
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right.
If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord.
If the carriage still does not move to the right, continue with the steps below.
Disconnect the power cord from the all-in-one.
Remove both print cartridges.
Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
Close the print cartridge access door.
Plug in the power cord.
When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
SEGGUSTION #2 cleaning rollers
Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers:
Figure 3: Paper feed rollers
Turn off the all-in-one and unplug the power cord.
Remove the rear access door (as describe above in this document).
Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred).
Rotate the rollers to clean the entire surface.
Verify that the paper feed rollers on the rear access door are clean and rotate easily.
Re-seat the rear access door.
Plug in the power cord and turn on the all-in-one.
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
