SOURCE: can not play DVD made on Toshiba combo in computer
You might try downloading (free) VLC Media player; it has dealt with a variety of formats that others don't:
VLC download
If it works for you, comment back here (to this thread) for the benefit of others-
SOURCE: I need to obtain an
Hello larry strunk,
if you click on the website below, it will take you to a website where you can download the manual. Just scroll down and you will a owner's manual in a pdf format.
http://www.helpowl.com/manuals/Toshiba/DVR670/10589
Good luck,
Joe
SOURCE: DVDs recorded from VHS with Toshiba DVR670 will
Possible that the format is not recognised or if a program needs to be installed into the PC for playback.
If the VHS was not compressed and then digitised , the format can be having errors and so is not playing. we need to cross check this out before we can confirm the error.
Please test with the recorded version on another PC and also try with another recorder.
SOURCE: toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
