Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
Fuel/oil mixture ratio huskvarna 350 - Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
Posted by shearerfamil on
Andrew White
  • Husqvarna Master
  • 2,239 Answers
With Husqvarna two stroke oil it should run at 50-1, with other two stroke oil run it at 25-1 as we do not know the quaility of other oils, always try to use Husqvarna oil.
Posted on Nov 26, 2012
5 Related Answers
J. Bradshaw
  • 121 Answers
SOURCE: I need to know oil/gas mixture for husqvarna chainsaw
40 to 1 is the ratio.
Posted on May 05, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: what is the ratio of oil and gas mixture for
Find an Operators and an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel ratio 50:1 = 1gal premium/2.6oz quality 2-cycle engine oil
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 07, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: what is the mixture of oil and gas
Husqvarna recommends 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
dontbother10
dontbother10
  • 2220 Answers
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Posted on May 10, 2010
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: OIl gas mixture ratio?
one small bottle of oil from the auto parts store ( i don't know the oz. size)to one gallon to one gallon of gasoline; mixed well
Posted on Jul 24, 2010
Lost the manual and need to know what the fuel and oil mixture ratio is
Hi Barney:
Fuel oil mix ratio for almost all newer 2 cycle motors is 50:1
Cheers
Apr 16, 2016 | Garden
Need to know oil mixture for older huskvara chain saw
"All Huskvarna 2 stroke products use a 50:1 ratio.."
https://www.youtube.com/watch?v=dsY8LRNDKKI
Dec 02, 2014 | Garden
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
McCulloch MAC 60 SX trimmer fuel mixture ratio is?
Check the links below for fuel/gas ratio.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
May 26, 2014 | McCulloch Trimmer Plus Attachment: Add On...
What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Oct 03, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
Fuel/oil mixture
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
From Poulan website:
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas. If you have other brands of equipment that require different fuel/oil ratios and you don't want to mix separate fuel cans, you should use the lowest numerical ratio. For example, if you have products requiring 40:1, 50:1, and 32:1 ratios you should use the 32:1 ratio for all products. This may cause slight smoke increase in the exhaust in the 40:1 and 50:1 products due to more oil in the fuel, but it won't damage either of the engines.
Aug 15, 2011 | Poulan Garden
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
234 people viewed this question
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
