Sewing Machines Logo
Robert Mcgill Posted on Nov 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New home machine model 677
Material gets rucked up when sewing
sylviaivie
Level 3:
  • New Home Master 1,564 Answers
  • Posted on Nov 25, 2012
sylviaivie
New Home Master
Level 3:
Answers
1564
Questions
Helped
425788
Points
3583
What do you mean by "rucked up?" You'll need to be more specific. Does the machine gather or pucker the material?
5 Related Answers
Anonymous
  • Posted on Feb 26, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Anonymous
  • Posted on Sep 23, 2008
SOURCE: I need the manual to Euro=Pro, Model 7500, Craft N' Sew Please..
http://homeappliance.manualsonline.com/ex/thread/view/idThread/159782
This one is in 3 languages, but it is worth the read. The diagram to choose the patterns from the frony of the machine are on page 28. Hope this helps.
Anonymous
  • 268 Answers
  • Posted on Sep 24, 2009
SOURCE: my kenmore sewing machine model 385.18221 is not
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
thepurush
Purushotham Racharla
  • 25 Answers
  • Posted on Oct 17, 2009
SOURCE: I have a Singer Sewing Machine Model 4562 T I
Change needle. It should be alright
bargainbox
Hassy
  • 1388 Answers
  • Posted on Oct 18, 2011
SOURCE: New home sewing machine model HF106 have been
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
New Home 534 Sewing Machine. What year was my New Home manufactured? Serial No 27302.
Question edited for clarity, make model (what it is)
Question moved form Sports and Outdoors.
1879!!
How Old Is My New Home Sewing Machine? (Models, Value)
https://sewingiscool.com > ... > Vintage Sewing Machines
Where to Find the Serial Number On a New Home Sewing Machine - The New Home sewing machine Company was not creative or innovative when it came to ...
When Were New Home... · ‎Where to Find the Serial... · ‎How to Date a New Home...
People also ask
How do I find out how old my sewing machine is?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Where do I find the model number on a new home sewing machine?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Are Janome and new home the same?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Who Made Modern home sewing machines?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Feedback
New Home Sewing Machine Company Manufacture Dates
https://ismacs.net > newhome > manufacture_dates
A CHANCE discovery by Judy Armstrong allows ISMACS members to date New Home machines from day one-1879 until 1930. Serial numbers, Date, Style. 181,702, 1879.
New Home Sewing Machine: Models, History, Value - Silver ...
https://silverbobbin.com > new-home-sewing-machine-...
New Home Sewing Machine Serial Number - This list does not include all of the antique and vintage New Home serial numbers, though. You can also try Janome's ...
History of New Home Sewing... · ‎Is Janome the Same As New...
I need a manual for a New Home sewing machine model # 1300
All the main companies are listed here
https://blog.treasurie.com/sewing-machine-manuals/
This is the go to site for older machines, but is not working for me.
Downloadable Sewing Machine Manuals
http://ismacs.net > free-sewing-machine-manuals-list
New Home: Brochures/maintenance instructions/info etc. New Home attachments. PEGASUS. Various models (parts manuals). PFAFF. Pfaff 463 industrial ...
Google thinks your machine is a Bernina, so New Home would be the Model Name and 1300 is the model number. There is also a Brother 1300. https://www.google.com/search?q=new+home+1300+sewing+machine+manual
How to get the light bulb out of new home 605 sewing machine
A manual may be helpful:
New Home Sewing Machine Manuals Instruction and Repair Manuals
New Home Model 605 Sewing Machine Instruction Manual
Janome New Home sewing machine instruction manuals
http://www.sewusa.com/Sewing_Machine_Manuals/New_Home_Sewing_Machines.htm
If it is bayonet type bulb, you may have to push in on the bulb and twist simultaneously. (Rubber fingertips are very helpful!)
Other bulbs simply unscrew.
However, there are also some machines (mostly newer models) which require the bulbs to be replaced by a technician.
1helpful
2answers
Machine is 30+ yrs old and tension settings .. There are 3.. Are all screwed up so stiches are not even, tight or inform...can someone help me know the normal setting and how to adjust for zigzag...
You haven't mentioned a brand or model number. Go to this YouTube page for general repairs and setting up zig zag.
https://www.youtube.com/results?search_query=how+to+adjust+seetings+on+sew+machine+for+zig+zag
But in any event, go to the manufacturer's website and go to the support page. Download the user manual, if they still have them, for your model. Settings should be located within manual.
Tighten the pressure foot
We have a sewing machine that was manufactured by Janome. It is a New Home Deluxe Model. It has very little travel on the pressure foot itself versus other sewing machines. I have learned just by using this machine.... If you need to get the foot up high...all you have to do is reach through and grab the pressure foot and while picking it up(not the lever but the foot itself) turn it clockwise just a touch and it will stay up plenty far enough to get larger or thicker material under it to sew. I hope this helps. Thanks and remember "Be Easy!" Neighborsboy
If you need further help, reach me via phone at https://www.6ya.com/expert/greg_012fb269876eb4b0
New home sewing machine model 677 material rucks up when sewing
Well that's a new one. What does "rucks up" mean?
Just pick up a new home sewing machine model 532. i would like a instruction manual and service manual. don't know much about this machine except made in 1964. don't want to spend alot for manuals because...
What a cool looking machine. Of course, I'm partial to the older metal ones. It probably needs a real good clean and oil as in most cases, these machines have not received the TLC they deserve. Although these machines may not garner much monetarily, they are worth much more for their ability to sew through a lot of materials the newer computerized machines will not.
Wheel on right side that controls the needle up and down is very tight...
JANOME NEW HOME Model 532 Sewing Machine Demo
Instruction Manual Janome Newhome 532
Although this is not your particular model, it will probably be helpful since most close model machines are similar.
New Home 535 Manual Instruction
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Top New Home Sewing Machines Experts
NOEL
NOEL
Paul Bade
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
