SOURCE: Sony VAIO PCV-V100G PC
yes reinstall the tv tuner software.
there might be some other applications conflicting the same.
SOURCE: SONY VAIO PCV V1G
Model:PCV-V1/G
Unplug everthing and place PC face down on bench with base over edge. Earth yourself.
Swing pc unit forward and unscrew the case retaining screw on both sides of the pc unit, swing unit other way and remove other two screws. Case can be loosened, pull large cover up and remove both sides. Parts are then exposed. A shiny metal box covers the memory on the left side of the PC unit. Remove tape that retains it,slide and lift off from the edge facing you.
Memory slots are then exposed....insert and reassemble PC.
Ten minutes tops....good luck, much better performance.
SOURCE: trying to open the case for Sony VAIO PCV-RX540
Go Here
Scroll down to Overview & General Info
SOURCE: cpu fan control wont stop running
I had the same problem. Luckily, I found the "Sony Fan Control Driver" here:
http://esupport.sony.com/perl/swu-download.pl?template=EN&upd_id=170&os_id=6,7&mdl=PCVRX450
Runs nice and quiet now!
SOURCE: how to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
The memory ram have buggered up if you have two of them pull one out and try one at ta time.
