Laptop keyboard is not working
Acer asper 5100
Posted by Vincent Raj ... on
  • 2 more comments
  • Vincent Raj Kumar.C.R. Nov 25, 2012
    NO,when i on lap,it will ask to press f2 key to comtinue...
    bt i cant acess the key board...
    i think it is due to keyboard controller ic..
  • Brian Sullivan
    Brian Sullivan Nov 25, 2012
    which operating system ? Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-fre... it might take some time being a freeware driver solution Note: it will find all of your outdated drivers You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
Laptop keyboards are a little more delicate than keyboards used in desktop computers. Hence they face more problems.
Normally, they are replaced when they render defective. However, most of these keyboard issues can be taken care of or even prevented by regular cleaning.
Common issues like, keys not working on your keyboard, having to press keys firmly to get the output or any keyboard typing issues, can easily be handled at home.
Sometimes you may find certain keys of your laptop's keyboard to not be working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result.
You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication.
Therefore you are supposed to maintain your laptop's keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
To start with, take out each key. Use a small screwdriver to carefully pry each key by making it loose.
As they become loose, keys will simply pop off.
Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water.
Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone.
This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
Once you have cleaned and lubricated all the parts, carefully reassemble the keyboard. Begin with placing all rubber components on the keyboard.
Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
The complete process will take you a maximum of 2 hours. Cleaning and lubricating the keyboard in the above prescribed manner once a year, can prevent many such situations.
Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem.
This was all about solving your laptop keyboard problems that you can try out yourself. After trying all the above given options, if you still find the keyboard still not working, you will have to take your laptop to a service center to get it repaired
Hope this helps.
Posted on Nov 25, 2012
Can I use a regular desktop keyboard with USB plug into my older laptop Acer 5100? If so how does it work?
May need to download proper driver if Windows doesn't install them automatically. Power down plug in and restart.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Feb 20, 2017 | Acer Computers & Internet
My acer 5100 aspire laptop's mouse and keyboard
I think you have disabled them.
There should be a key to enable mouse and keypad.
Jan 27, 2010 | Acer Aspire 3680 Laptop
The keyboard and mouse will not work when I power on my acer aspire 5100 laptop. I have no control of the computer. How do I fix this?
Try pluging in a external keyboard and mouse see if that resolves the issue, if it does then use that keyboard and go into the comtrol panel and check if something is checked off in the keyboard icon.
Oct 22, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Jul 21, 2009 | Acer Aspire 5100 Notebook
Acer 5100
Is the keyboard on the laptop working? Also Does it recognize when you are plugging in the usb device? Go to your device manager and see if there are any exclamation points. Its possible a driver is corrupt or not installed.
Thanks,
Lee
Jul 11, 2009 | Acer Aspire 5100 Notebook
Keyboard and mouse pad on my laptop. Acer 5100 vista
On an Acer, the Fn key plus F7 will turn the touchpad on and off.
Try that to see if it works.
Mar 22, 2009 | Acer Aspire 5100 Notebook
My acer aspire 5100 as put me into trouble
i had the same problem. apart from keyboard and mousepad, all usb weren't working at all... except the pcmcia slot. so i bought a pcmcia usb card and plugged in the usb mouse and keyboard in those slots. it works! at least on my aspire 5100
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Acer 5100
Dear reggi_soq,
If your laptop keyboard is not working and you need to press a key to boot from a CD, try installing an external keyboard (either USB preferably OS2).
Jul 29, 2008 | Acer Aspire 5100-5022 Notebook
Acer aspire 5100 model bl51
dear friend,
this is your system board fault
this is due to southbridge (ich4) or ATI (ixp460) dry sold damage.
you should change this ic to fix this.
go to the best repairing center near you.
Apr 09, 2008 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
89 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
