Washing Machines Logo
A
Anonymous Posted on Nov 24, 2012
How we get off the demo function?for ariston avxd109
The washing machine is in the demo function and i can't get over with this..
Ovidiu Gabriel
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 22, 2023
Ovidiu Gabriel
Contributor
Level 1:
Answers
Questions
0
Helped
1024
Points
Hold power up and start program together for 1 second then it says DoExit
5 Related Answers
Anonymous
  • Posted on Apr 10, 2009
SOURCE: ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Anonymous
  • 11896 Answers
  • Posted on Jan 02, 2010
SOURCE: my ariston washing machine door not locking
I recommend replacing the door latch. It is a fairly common problem. You can get one at repairclinic.com or partselect.com
Anonymous
  • 41 Answers
  • Posted on Jan 09, 2010
SOURCE: We have an Ariston A1636S Washing Machine. When
COULD BE SOMETHING IN THE DRUM UNDER THE CROME PIECE THAT THE CLOTHES GO ONE
Anonymous
  • Posted on Jan 23, 2010
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 27, 2010
SOURCE: I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
How do I run the first cleaning programme for the new machine.. I can see the button to press but what washing cycle I put. I cannot have "wash cycle number auto clean" as the booklet says.
First, I'm not a Ariston Representative.
* Check your warranty. Call for service.
*** The following is for information only.***
* Page 4 of instructions;
" The washing machine has a auto clean programme for its internal parts that must be run with no load in the drum"
* your basically run the machine empty (no clothing)
* There is no specific "Auto cleaning cycle" button.
* Instructions; https://aristonbrand.com/media/RSF-82-B-AUS_GB.pdf
* The "Cleaning action" (page 6) is just an indicator to tell you what part of the cycle your in.
* Demo of features (Official); https://www.youtube.com/watch?v=NF_ZNDir_38
* Specs; http://aristonbrand.com/inventory/rsf-82-b-aus/
* Brochure; http://aristonbrand.com/media/RSF82BAUS.pdf
* Product review; https://www.productreview.com.au/c/front-loading-washing-machines/m/ariston.html
Aloha, ukeboy57
PS; for some reason Hotpoint keeps getting matched with Ariston;
* Hotpoint (similar?) auto clean; https://www.youtube.com/watch?v=a9cgkHlb6Fg
* Hotpoint (customer) Demo; https://www.youtube.com/watch?v=qSEGjd0HGBg
1helpful
Ariston washing machine. Error code F09
Most Indesit ( Hotpoint, Ariston) machine's 'F09' decodes as ' incompatible eeprom' or eeprom error, check/change eeprom'. Sorry, whichever it is requires an engineer call ;-0(
Hopefully it might only need connectors reseating.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
4helpful
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Ariston L64 dishwasher first 2 lights flashing what does this mean please!
Ariston LI6401-Washed a load. Last light on R control panel (Eco Wash) is blinking rapidly and didn't dry the dished.Turned pwer off then on. Did same type of wash. New maching-This is about the 6th wash
1helpful
The machine is not working properly and at the lcd display it writes DEMO. how can i stop the DEMO mode.
Try:
Press and hold down the start and the on/off buttons together until the display says ' d off ' then release them.
6helpful
Amd129 shows demo on display but not functioning
If your ariston amd129 shows DEMO on the display chances are you put it on that program.To rectify press on/off AND program start button simultaniously for 30 seconds.
Error messages on my Ariston AVXD109
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Enquiry
Dear Abdelmotaal, Please give me the Brouchure of Washing Machine (Ariston AF552T) Function also.
Thanks
[email protected]
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
